Report generator
Started by viking9, November 05, 2008, 05:09:16 PM
viking9
Why does Reporter not produce all the information that is in MyLog? Is it a bug or a 'feature'?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
What else would you like to see in Reporter?
viking9
How about first time seen as well as last time and the last squawk?
Those would be useful in pinning down non-positional aircraft seen overhead.
Tom
15 miles SE of EGUN
HMN851X
One thing I would like to see in the Report generator is all flights. I try to track flights in and out of my local Airport but the Report only shows the first flight of the day by the Aircraft for example
NPT501 crosses the Isle of man at 01:00 in the Morning but then arrives in the Isle of Man at 06:15 but this flight is not showen in the report :-(
this also is the same for Flybe flights as well
#4
HMN851X, yes, that's been asked for before - see http://www.airnavsystems.com/forum/index.php?topic=1399.msg11189#msg11189
I've posted SQL in that thread that will give you all flights for all aircraft for the previous day.  Attached is my report for yesterday, created using SQLite Maestro.
Here's the SQL I currently use for my daily report:
SELECT DISTINCT
  Aircraft.Registration,
  Flights.Callsign,
  Flights.Route,
  Aircraft.AircraftTypeSmall,
  Aircraft.Airline,
  Aircraft.AircraftTypeLong,
  Flights.StartTime,
  Flights.EndTime,
  Aircraft.ModeS,
  date('now','-1 day') AS FIELD_1,
  substr(Flights.StartTime,1,4)||"-"||substr(Flights.StartTime,6,2)||"-"||substr(Flights.StartTime,9,2) AS FIELD_2
FROM
Aircraft
LEFT OUTER JOIN Flights ON (Aircraft.ModeS=Flights.ModeS)
WHERE
  (FIELD_1 = FIELD_2)
ORDER BY
  Flights.StartTime,
  Flights.EndTime,
  Aircraft.ModeS
#5
I've been working on a new SQL query that lists ALL aircraft received yesterday, including those without a Flight ID.  SQL listed below, and example report attached.
SELECT DISTINCT
  Aircraft.Registration AS "Reg",
  Flights.Callsign AS "Flight ID",
  Flights.Route AS "Route",
  Aircraft.AircraftTypeSmall AS "ICAO Type",
  Aircraft.Airline AS "Airline",
  Aircraft.AircraftTypeLong AS "Aircraft",
  substr(Flights.EndTime,12,5) AS "Flight Ended",
  Aircraft.ModeS AS "Mode S"
FROM
Aircraft
WHERE
  ((date('now','-1 day') = substr(Aircraft.LastTime,1,4)||"-"||substr(Aircraft.LastTime,6,2)||"-"||substr(Aircraft.LastTime,9,2)) AND
  (Flights.StartTime IS NULL)) OR
  ((date('now','-1 day') = substr(Flights.EndTime,1,4)||"-"||substr(Flights.EndTime,6,2)||"-"||substr(Flights.EndTime,9,2)))
ORDER BY
  Reg,
  Flights.EndTime,
  Aircraft.ModeS
