squawk code decoder
Started by radarphil, November 11, 2008, 04:34:30 PM
radarphil
i have down loaded the squawk code decoder it says thet it has connected but the decoder is balnk and not decoding.it says thet is uses port 30003 to operate,how do i find the port 30003 ,can anyone help me to get the peogram started .
regards
phil
Tailwinds
I'm not sure if this is the solution but have you got the squawk codes txt file in the same directory as the .exe
radarphil
got it working perfectley now thanks.
viking9
Hi Guys,
Where is the decoder file located?
Thanks,
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
besty
besty
viking9
I've downloaded it and will be trying it out tomorrow.
Cheers,
Tom
Tom
15 miles SE of EGUN
radarphil
squawkbox works fine no problems with radarbox and SBS-1 GOOD WORK !!
defcon333
hi all,
how lucky you are over there in Britain having all the information available, but what about us the "poor" poeple in Germany? anyone out there who knows about those German codes (where to find, how to implement?)? any help would be appreciated especially for me (my knowledge about about pcs and how to e.g. change files is only very basic!)
thanks a lot in advance.
cheers   herbert
Andy Frost
Herbert, try this http://www.ivao.ch/Textes/squawk_codes_ch.pdf. A transponder (squawk) code listing for Switzerland, Germany and France. You'll need to create a new file squawk_codes.txt to replace the current one so that the contents match the table in the the pdf above.
That is, in squawk_codes.txt something along the lines of...
0401 - 0477 Entering Italy (Transit, Milano)
1201 - 1277 Entering Italy (Transit, Roma)
1401 - 1477 Domestic (Switzerland)
If you send me the finished file I can include it in the zip download of SquawkBox. The goal might be to get SquawkBox to detect which country it is being used in and have it use the appropriate squawk code file.
While I was looking I also came across Turkish squawk codes at: http://www.trvacc.org/web/training/ref/squawk.asp for anyone interested.
viking9
Hi Andy,
Downloaded and operating under Vista SP1 with no probs.
Thanks,
Tom
Tom
15 miles SE of EGUN
Andy Frost
Tom, Thanks, it's always good to hear that it works under Vista. I developed it under WinXp.
nbquidditch
Hi guys, my 1st evening with Radarbox & just set up the Squawk software & running perfect on Vista too. Can anyone direct me some more goodies I'm loving it.
EGBB
Hi Mr Nbquidditch and welcome!
Most features are built into RadarBox, so you don't need much more. May I sugest that you update the airline logos by visiting this thread: http://www.airnavsystems.com/forum/index.php?topic=1293.0, and add airport outlines by visiting this one: http://www.airnavsystems.com/forum/index.php?topic=717.0.
There are more goodies around - have a good read of the forum - lots of pearls here!
Enjoy!
defcon333
hi andy,
i tried the link above(#9) but this is only for switzerland. i did a lot of search yesterday but unfortunately i did not find corresponding German pages with the ssr codes ( e.g. aip, ais etc). any idea?
cheers      herbert
