Updating the database
Started by GreekSpy2001, January 12, 2018, 08:57:16 AM
GreekSpy2001
I regularly try and update the database.  However, when I restart the software it does always register that its is updating the newly downloaded data it just says that it is optimising the database as per a normal restart. This will happen approx 50% of the time.  I always choose the option to overwrite changes as I never update the db with my own data.  Does this mean the update has not worked and I have to go thru the process again?  Or is there a way I can check to see if the update has actually been apply?  Gets very frustrating having to do the same upgrade multiple times.
Graham
No idea on your query Graham as I have not seen that but I suggest that you can check the total rows on the aircraft table before and after to see if they marry up or if there is a difference.
Make sure that you give the app time to close down fully before starting it up again.
GreekSpy2001
Ok happens regularly for me closing down and waiting doesn't seem to make a difference as to whether it works.  Problem is you don't know when its going to happen so you have to make sure you have made a note of the rows.  Something for which I know I will remember after the event!!!  Will try again now as it has just gone thru this.
Todays up date should give you 260203 rows
GreekSpy2001
Just checked and yes I have 260203.  So it looks like it did work but the startup screen didn't say it was applying the updated db.  So I can live with that only a minor bug on my installation.
G
