micro radarbox
Started by sergiomaria, January 14, 2018, 03:16:23 PM
sergiomaria
Good afternoon,
i got a micro Radarbox and i would ask:could i set micro radarbox near the antenna and connect the receiver to computer by an amplified  usb 10 mt long usb cable?Could i get better performances?
Thank in advance
Sergio
I don't think it would help unless it cut the antenna cable distance by a good bit.  Do you have a long antenna cable run?
sergiomaria
hello Alan,
coax cable lenght is about 12mt but is a low attenuation cable,12.8 dB for 100 meters...
12m is not an excessive run so while cutting the length may make a difference fitting a low loss cable suitable for 1090Mhz may give better results.  I suppose your option will however be more economical and be sufficient for your needs.
