Alert Feature Issue (Beta Patch Report)
Started by DaveG, August 07, 2007, 10:29:53 PM
DaveG
This is a strange one and will need other to confirm please.
When I set an alert up that I know will happen within a few minutes nothing does....  That is until I either restart RB, disconnect and reconnect the feed.
Example:
Setup alert to email and notify on screen when:
FlightID  EIN739
Range    90 nm
From      Home location
Now if I sit and watch the flight come within range nothing happens, as soon as I do one of the above (restart or disconnect/reconnect) then the alert happens.
Tried it a few time with different alert settings and different aircraft both live and network, always the same result, nothing happens unless I (restart or disconnect/reconnect)
Can someone else have a try.
Cornwall, UK
DaveG
Also had a few Error messages stating it could not send email and to check anti-virus/firewall with Alert log reporting it could not connect to SMTP.
Cornwall, UK
Anti-Virus software causes this to happen. Disable on-access scan and it will work Ok. We are seeking ways to solve this situation, maybe by having a SMTP server inside the software, but it will not be ready for patch 1.
prbflight
Quote from: AirNav Development on August 07, 2007, 11:13:20 PM
Hopefully this will solve my problem of not being able to send reports.  I've tried just about everything I can think of including other RadarBox owners suggestions with no luck.
Paul
