Author Topic: Getting Changes to 'Stick'  (Read 8258 times)
9M-ISJ
« on: November 22, 2008, 10:42:02 AM »
I am sure it me doing something wrong again... but every time I restart RB it seems to revert to the 'default' settings for colours and trails on.
I am going FILE>PREFS>MAP Colours and OKing and Applying, but each time I restart the colours have reset.
Same with trails, it seems to be ON every time I restart.
Gulfstream
Re: Getting Changes to 'Stick'
« Reply #1 on: November 22, 2008, 10:56:44 AM »
MAP - SAVE MAP AS and name it Default.ml3
9M-ISJ
« Reply #2 on: November 22, 2008, 09:31:45 PM »
As ever,,, thank you.
Been a RB user for just over 24 hours now... and very pleased that I have made the switch from SBS
Now if somebody could just iron out the bug with trails on, trails off - I would be home and dry.
The SBS box is now sitting awaiting its new home (dont want to leave it too long - scared the buyer will discover RB and change his mind!)
Gulfie
9M-ISJ
« Reply #3 on: November 22, 2008, 09:54:05 PM »
Ummmm, not actually working this!
Still reverting back to the original default colours (red for climbing is my problem!! - too long of seeing red as a timeout plot)
Not a major issue, but would be nice to resolve
« Reply #4 on: November 22, 2008, 09:59:34 PM »
9M-ISJ, save your colour scheme in the Preference dialog box, on the Map Colours tab.  It should remember the colour settings then.
9M-ISJ
« Reply #5 on: November 22, 2008, 10:07:04 PM »
Thanks Tarbat,
That has worked for the colours.... it still defaults to TRAILS ON at each restart.
Gulfstream
oceans777
« Reply #6 on: November 27, 2008, 08:39:11 PM »
Having the same problem here with the new Military Operating Area outlines. I change them to red (Type 25), save Map as Default.ml3 and also Export my color profile. When RB re-launches they go back to gray.
Blackthorn
« Reply #7 on: November 27, 2008, 10:43:36 PM »
I am also having the same issue with the default to trails on each time I start the program.
nbquidditch
    • Narrowboat Quidditch
« Reply #8 on: November 28, 2008, 08:01:48 AM »
Hi guys it's a bit confusing & I had the same problem. The way I do it (I'm sure there are other better ways) is to go to preferences in the file menu & the map colours. Change the colours to your preferences and then click on Export. Type the file name of your choice & save. Then once your RB has fired up go to the Map Colours icon just below help and click on the drop down, your new file should be in there & then just click on it.
I discovered this myself after many attempts. If anyone know an easier way then let me know ;)
