My Log?
Started by nbquidditch, November 24, 2008, 11:44:13 AM
nbquidditch
Hey guys a quick question about My Log!
I was monitoring a helicopter visually as it passed overhead but nothing was showing in the My Flights section. I know the helicopter well, it belongs to JCB and flies over quite regularly. It normally appears!! When I went to My Log for the previous 10 minutes it was showing. What could be the reason it was not showing in My Flights but found it's way onto My Log?
Cheers.
You may have had filters on in your MyFlights such as showing ADS-B flights only. Check none are set by clearing them and clicking show all.
nbquidditch
Thanks.. No I had Show All at the time!
If it appeared in the MyLog it would have been picked up and the only way you didn't see in the list is if there was filter otherwise it wouldn't have been in MyLog.
Did you have lots of other aircraft on the screen at that time and might have been further down the list.
As what you describe does not make sense.
nbquidditch
MMM.. There was a lot of other traffic in the My Flights so I suppose it's possible I did miss it but I'm almost certain I scrolled down! If the My Log is generated solely from the My Flights then I must have missed it I suppose.
