Why can't I see flights on the map?
Started by golden417, November 25, 2008, 04:40:54 AM
golden417
I have just started playing with my RadarBox.  I have seen flights show up in the MyFlights section, and been able to also see them in the map.
however, now I can see quite a few flights in the MyFlights, but I cannot see them on the map.
1) How do I tell the program to show me where the flight selected in MyFlights is on the map?  I clicked "Pan Map with active flight", but nothing happens.
2) I noticed in the MyFlights section that I can see the plane's altitude, (normally status is Cruise or Levelled), but the Lat Long columns are blank.  Could it be that I am picking up the flights, but am not receiving position info, and that's why they aren't on the map?
Thanks for any help you can offer!
Quote from: golden417 on November 25, 2008, 04:40:54 AMI noticed in the MyFlights section that I can see the plane's altitude, (normally status is Cruise or Levelled), but the Lat Long columns are blank.  Could it be that I am picking up the flights, but am not receiving position info, and that's why they aren't on the map?
See http://www.airnavsystems.com/forum/index.php?topic=1329.msg13437#msg13437 for an explanation of what's happening.
The reason why you're not receiving position info is that the aircraft concerned aren't transmitting it !
Hi golden417,
Regarding question 1, just double click the Flight in the MyFlights List. If it has a globe icon it is transmitting its location and the map will center on it.
