Route details not displayed
Started by RodBearden, November 26, 2008, 11:29:33 AM
A little annoyance:
When an aircraft has a valid callsign and route, but no aircraft details, the photo/details panel doesn't display the route details, as in the attached example.
Would AirNav please change it to show the route details, even if no other info is available?
QF1
Some of the information that is generated from the database seems quite random.  I have two AAL flights on the screen with no routing, although all other info is showing.  The flights have info in the database but not displayed on the radar screen or next to the photo.
This can be a small problem in the programming of the application: if you can find an exact way of reproducing it we will add it to the bug report list and have it corrected for V2.10.
