Main Menu
AIRPORT OUTLINES
Started by ig, November 28, 2008, 08:43:50 AM
ig
Hi all,
Can anybody tell me where I can get airport outlines from please & where do I put the files when I've downloaded them?
nbquidditch
ig
Thanks again.  I've got RB2009 and after a little playing found that airport outlines are already with this.
Do you have any idea how to update this as more airports and hex codes are known?
IG
Blackthorn
You just add any extra outlines you require and have downloaded in to the outlines folder.
ig
Hi Blackthorn,
      Thanks for your prompt reply.
Regarding the post from nbquidditch and his suggestion of looking http://www.airnavsystems.com/forum/index.php?topic=717.0
I couldn't see any downloadable outlines that are in the same format as what is already in my outlines folder. The ones I saw were in a spreadsheet.
Apologies if I seem dumb, but SBS is very new to me
IG
Which specific airport outlines do you want?  If you're running RB2009, there should already be several outline files in the Outlines folder.  They have a .out extension, for example Blackpool EGNH.out.  So, any file that ends with .out is an outline file.
Not sure what you mean by "The ones I saw were in a spreadsheet".  Can you give us an example.
For other UK & Ireland airport outlines, also see http://www.homepages.mcb.net/bones/Kinetic/Kinetic_Utilities.htm
ig
I'm after all UK & European airport. I've looked on Bones site and downloaded the UK military airfields but I can't see a link for the UK airports
Over 120 UK airports are in the main outlines download on Bones' site, in the "UK & Ireland Airspace" download.  For non-UK airports, you'll need to search through the other thread - http://www.airnavsystems.com/forum/index.php?topic=717.0
ig
Mis-read the notes. I was looking for a download link as there is with Mil.
Thanks again
ig
Thanks for all your help.
IG
