OMG! Disaster.....RB User failure!!!
Started by Tramline, December 05, 2008, 12:37:31 AM
Tramline
I had RB running without USB connected, I then put the USB back in and I lost all my alert data, the blue light was flashing at regular intervals and only a few a/c showed on my map. In desperation, I uninstalled RB, and re-installed the software, but when I put the USB back in I didn't get the 'new hardware located' from Windows Vista.  Still I ploughed on and replaced all my alert data and as a test, turned RB off - and I lost all my alert data again.  The map opens to near full screen on opening.    But something is very wrong and I'm totally demoralised.  I'm a technophobe and this is my nightmare - and its only day 2!
When you add alert data is there a save button?   What procedure should be taken when removing and replacing the USB?
Can anyone help because I'm off to bd after midnight feeling thoroughly fed up!
Located 2 miles South of LHR.
I think your alert settings (and other settings) only get saved when you exit from the program.  So, to make sure they're saved, exit Radarbox.
You didn't really need to reinstall.  But uninstalling and reinstalling will not have removed the RB drivers, so don't worry about that.
When you say "......turned RB off - and I lost all my alert data again", how did you "turn RB off".  Either click the close button, or use menu FILE......EXIT.
As for removing and replacing the USB, I can't answer.  It's not something I ever do, and I guess I'd ask "why?".  Best advise is probably to close Radarbox before unplugging the USB.
Tramline,
I agree with tatbat in that it's probably not a good idea to unplug/plug the USB lead in when RadarBox is running.
Did you plug the USB lead back into the same USB socket, or might it have been a different one?
Tramline
First of all, apologies to AirNav RB.  It was user failure.  I didn't realise that you had to 'File' 'Exit' to save changes to Alerts.   Might I suggest that the Alerts page has a 'Save changes' box? It seems obvious to me that such a box would have allieviated my error.
I had RB running with the USB in and then plugged in the USB, I wasn't recieving any alerts because I had failed to File / Exit - but had assumed my plugging in of the USB had deleted all my hard typed efforts.  I did this twice as well!
The RB is working very well, though I've not had time to 'play' with it, but upto now I think it's excellent.  Once again, thanks to all for your help and answering my questions.
Tramline, I agree with you, a "Save Changes" box is really needed.  Airnav, how about adding that to the enhancements list?
We had a lot of power cuts last week, and I kept losing my alert settings as well.  That, and we're running out of candles!!! :(  I do wish the geese (non-ADS/B) would stop flying into the power lines - at least, that's the latest excuse from Scottish Electric!!   I'm seriously thinking about getting a decent UPS for my PC now.
Deadcalm
You can add my interest to the "Save Changes" facility idea - we're susceptible to sudden power outages here in rural France, too.
DC
Quote from: tarbat on December 08, 2008, 03:29:25 PM
We had a lot of power cuts last week, and I kept losing my alert settings as well.  That, and we're running out of candles!!!    I'm seriously thinking about getting a decent UPS for my PC now.
Hi Tarbat, we're dependent on local overhead cables, and being subject to 100+mph winds get more than our share of outages.    Bought an APC UPS back in 2001, when my wife was writing her degree thesis - we couldn't afford to lose any of that - it's still on its original battery, I'll occasionally deliberately discharge it (19" CRT monitor about 20 mins) and it does virtually as long now as when brand new.    A very worthwhile investment if you're running a desktop.    I can't remember if it came from Dabs or Novatech, but was around £100.    An alarm sounds with any power outage/voltage drop below 200v, and you'd be amazed at how often it sounds - light bulbs just dip a bit.
