Antenna change - polar diagram
Started by Deadcalm, December 08, 2008, 03:57:13 PM
Deadcalm
Having suffered some water ingress problems with my Wimo antenna, I decided to get hold of a BS1100 (with AS1100 Hi-gain whip) to tide me over whilst I waited for Wimo to sort me out a replacement.  I thought the Wimo was good, but the BS1100 has extended my range even further (pre-amp used with both), so I'm quite chuffed.
DC
mt007
Dead,
is amazing!!!!
Great job.
Regards.
flightchecker
#2
Hi Deadcalm,
it's me again, Karl. We "met" some time ago when it was about your "drowned" GP 1090 as above.
Do you think, you could generate two overlayed polardiagrams with both of the antennas (one after the other, about the same plotting time, about same time period of day) you're refering to? The longer in time the better, as statistics will take care for an almost "equal opportunity data gathering".  Would it make easier to judge then.
Kind regards
Karl
Deadcalm
Hello again, Karl
I can do this eventually, as I sent the "leaky" antenna back to Wimo last week and I await a replacement.  When it arrives (and we get a dry day which isn't freezing cold!) I'll put the Wimo back up and do as you suggest.
I did do this polar diagram earlier this year, with the Wimo, and you can see the difference...
DC
flightchecker
#4
My goodness: you're fast !!!! DC,
Would be great if you could proceed as suggested. I've done similar with my GP1090 and a SIRIO 2000 (discone)
Overlaying two polar diagrams (maybe even by using different colours, making it easier to distinguish) is an exellent approach in evaluating different antennas. The longer the plotting intervals the better. "Statistics", as said before
Kind regards
Karl
