New user with possible hardware problem - no USB or signal lights
Started by QF1, December 09, 2008, 02:33:44 AM
QF1
Thanks Allocator - that's great.
I am off to get a BNC/SMA connector today so that I can try my new Radarbox with my old SBS antenna which is up on the roof.
M
That's what I use when I'm at home - the good old BS1100 antenna that has been out in all weathers for about 18 months.  It works a treat providing the cable run isn't too long :-)
When I'm away, I just use the standard RB antenna on a window ledge - that works surprising well too.
HadNav
The RB standard antenna does work well on a window ledge. It can work better outside too with weather proofing, ie a homebuilt raydome. Plastic soccer balls work or something similar :) ie Basket Ball.
QF1
It is my intention to use the Radarbox when traveling, as it is smaller to carry than the SBS, so will use the standard antenna.  Likely locations, other than Australia would be New Zealand, Fiji, USA and Canada.
M
HadNav
QF1 I suggest you pack a basketball on your journeys :) Complete weather proofing on the move :)
HadNav
QF1. When you say the RadarBox is smaller to carry than the SBS1, do you mean, smaller box or antenna?
HadNav
When you pack your basketball, of course it will be deflated with a hole cut in it for the antenna and groundplane.
QF1
Quote from: HadNav on December 10, 2008, 04:20:01 AM
Smaller Box.  Antenna about the same size, although I think mag base is also smaller.  Also, no need to upturn the metal hotel bin for a ground plane as AirNav have provided in the box.
Small like this.  Note the patented coffee tin ground plane for use in the office and the range increasing modification - a CD-Rom "cake" box :-)
Tramline
Quote from: Allocator on December 10, 2008, 08:21:49 AM
Aha!  So am I right in concluding that the larger the circumference of the 'base' the better the reception?  I understand the height issue being key but I've several 'biscuit' tins available which I could place the antenna on.
I'm tempted to put my antenna in the loft, but then I've got to drill through the loft and then the antenna is basically in situ and I'll be unable to use my RB outside of the house.
Any comments or views?
Located 2 miles South of LHR.
daelight
In laymans terms, how / why would the coffee tin improve reception?
Thank you
Blackthorn
I was told that the supplied base disc with the antenna was almost the correct size for the base reflector and anything larger would not help. Is this correct?
I use the Kinetic whip mainly because it provides slightly better reception and my Airnav antenna was bent in the box. Too flimsy for my liking.
Quote from: daelight on December 10, 2008, 03:18:09 PM
Thank you
I was just trying to be funny - or maybe the brand of coffee makes a difference ;-)
The "CD" sized metal groundplane that comes with RB is the ideal size.  Having the coffee tin at work meant one less thing to carry around, so I used it instead of the AirNav item.
As far as the "range increasing CD case box" - more humour on my part, but believe me, elevating the antenna only a small amount can make a difference to live aircraft reception - it just raises the antenna a bit.
Blackthorn
Not being a coffee drinker I prefer to use a Quality Street tin lid you can get two for £8 at the momment :-)
Always good to have a spare.
That's expensive for just the lids - do you have to pay extra to have the sweets taken out?
