Database details
Started by jmhayes, December 11, 2008, 07:13:30 PM
jmhayes
I thought I might try my hand at making a customized report generation utility, so I looked into the MyLog.db3 file and am confused.  It doesn't seem to have all the data for all the flights I've collected.  Something simple like
   SELECT * from v_Flights where ModeS='ABC123'; (fake code)
returns no rows unless that code has been seen with a non-null Callsign block?
The Reporter seems to get this right; where's the data being stored?  :)
Tarbat is the one to ask here regarding SQL searches.
Only aircraft with a Flight ID currently get added to the Flights table.  That's under review by Airnav as a possible future enhancement.  Flight ID is the primary key, so a Flight ID will have to be "made up" for flights that don't have a Flight ID.
Aircraft without Flight IDs do get added to the Aircraft table in MyLog.
jmhayes
Quote from: tarbat
So where does Reporter get the others from?
The Aircraft table in Mylog
jmhayes
Oh, ouch.  Ok, back to the drawing board :)  Thanks.
