Can track a specific airline
Started by jamesod, December 21, 2008, 06:05:37 PM
jamesod
using the radarbox from ireland and it doesnt seem to pick any aer arann flights. what could cause this.
by the way only new to this
I seem to remember that aer arran do not fit Mode S transponders to their aircraft and therefore they will not show on RadarBox.  I'll do a bit of checking and get back to you unless somebody beats me to it.
#2
OK, an update to my last post, Aer Arann do have mode S fitted, but they do not transmit the full ADS-B information, so they will not appear on the map.  Also, as they don't display a Flight ID, you won't be able to search for them in MyLog.  However, if you look to see if you have received any on the company registrations, or use the filters in MyLog to look for Airline = Aer Arann (use the drop down for the airline) they should be there.
Registration   Manuf.     Model   Type   c/n   l/n     Reg/Opr   built     delivery   until   status
EI-BYO    ATR   ATR 42-300   AT43   161      REA   1989   2002-12-20      active
EI-CBK    ATR   ATR 42-300   AT43   199      REA   1990   1998-12-24      active
EI-CPT    ATR   ATR-42-300   AT43   191      REA            active
EI-CVR    ATR   ATR 42-300   AT43   022      REA   1986   2001-01-17      active
EI-CVS    ATR   ATR 42-300   AT43   033      REA   1986   2001-03-16      active
EI-REA    ATR   ATR 72-202   AT72   441      REA   1995   2002-05-30      active
EI-REB    ATR   ATR 72-202   AT72   470      REA   1996   2002-05-17      active
EI-REE    ATR   ATR 72-202   AT72   342      REA   1992   2003-12-10      active
EI-REF    ATR   ATR 72-202   AT72   201      REA   1990   2004-06-18      active
EI-REH    ATR   ATR 72-201   AT72   260      REA   1991   2005-09      active
EI-REI    ATR   ATR 72-202   AT72   267      REA   1991   2005-11-18      active
EI-REJ    ATR   ATR 72-201   AT72   126      REA   1989   2006-05-20      active
EI-REL    ATR   ATR 72-212A   AT72   748      REA   2007   2007-05-25      active
EI-REM    ATR   ATR 72-212A   AT72   760      REA   2007   2007-10-25      active
EI-REO    ATR   ATR 72-212A   AT72   787      REA   2008   2008-08-12      active
EI-REP    ATR   ATR 72-212A   AT72   797      REA   2008   2008-08-12      active
jamesod
I've got these in MyLog
ATR ATR-42-300              AT43       Aer Aran4CA1C0  Ireland EI-BYO
ATR ATR-42-300              AT43       Aer Aran4CA03B  Ireland EI-CBK
ATR ATR-42-300              AT43       Aer Aran4CA168  Ireland EI-CPT
ATR ATR-72-202              AT72       Aer Aran4CA1A7  Ireland EI-REA
ATR ATR-72-202              AT72       Aer Aran4CA1A1  Ireland EI-REB
ATR ATR-72-202              AT72       Aer Aran4CA299  Ireland EI-REG
ATR ATR-72-201              AT72       Aer Aran4CA2F5  Ireland EI-REH
ATR ATR-72-201              AT72       Aer Aran4CA2D1  Ireland EI-REI
Aerospatiale ATR72-212A     AT72       Aer Aran4CA593  Ireland EI-REL
Aerospatiale ATR72-212A     AT72       Aer Aran4CA5E4  Ireland EI-REM
ATR ATR-72-500 (ATR-72-212A)AT72       Aer Aran4CA66E  Ireland EI-REN
ATR ATR-72-...              AT72       Aer Aran4CA6AB  Ireland EI-REO
ATR ATR-72-500 (ATR-72-212A)...        Aer Aran4CA6D5  Ireland EI-REP
