Using Radar Box whilst ON an aircraft
Started by bailey_uk, December 23, 2008, 07:24:28 PM
bailey_uk
Hey folks, flew from Manchester to Barbados on Monday, and the temptation got too much to load up my Laptop and RB whilst in the middle of the atlantic and see what I could pick up!
The flight itself came up, showing correctly, but no other aircraft did, even when I could see them out of the window.
Was something id always wanted to do!
Anybody else done this?
marcdeklerk
A few others have done this as well and have picked up other aircraft. You may just have been unlucky in where you placed in the aircraft that ADS-B signals from others may have got blocked.
drskeptical
Quote from: bailey_uk on December 23, 2008, 07:24:28 PM
Hi bailey_uk
Many years ago I experimented with a new (then) GPS receiver I picked up from the USA. I was trying to watch our speed and direction whilst in flight returning home. It just did not work. I couldn't get any kind of fix. I put it down to being in a Faraday cage. Although there are windows in the side of the aircraft I suspect that there just is not enough signal. You picked up your flight ok, most probably because the field strength of the planes signal would have been very strong.
Next time you could always try winding down the window and placing the aerial on the fuselage... Mind you this could have some serious implications!!!
