Map Colours Question
Started by bailey_uk, December 31, 2008, 01:31:54 AM
bailey_uk
More than likely a problem with my PC than RB, but sometimes the background mao colours seem to appear 'dotty'. Ive taken a screen shot to show.
Anyone know why this may be?
Also, my chosen map colour (which I made my self) doesnt seem to stay as the default one, I have to keep on changing to it each time I load up the software. Is there a certain way to close the software down so that certain settings are memorised?
James
James,
Is your PC set to show the maximum number of colours?  Right click on the PC desktop, select Properties then Settings.  You need Highest (32 bit) Colour Quality.
Have you seen this regarding changing the map colours:
http://uk.youtube.com/watch?v=wzxU6q-xVeQ&feature=channel_page
You could also save (export) the map as default.ml3.  Even so, sometimes RB does start with the original colours rather than yours, but it's just a case of using the drop-down menu to select your choice.
The dots is because you have the day night shadow on, you can turn it of in the menu. It basically shows the day/night shadow across the globe.
bailey_uk
Oh thanks Allocator, just needed to know if I wasnt closing it down correctly
Air Nav, yep that makes sense!
