JFK
Started by dca, January 03, 2009, 07:33:52 PM
dca
Just a note to let all know I am working at JFK from tomorrow (Sunday 5th) until Friday. All being well you should be able to view my delayed data Sun-Thu evenings from around 1800 local, 2300z until around 2300l/0400z. I'm staying at one of the airport hotels so hoping for good reception!
9 nm south of LGW
Brilliant, Look forward to seeing your flights on the network.
QF1
I also should be sharing from JFK at the end of this week.  I am still not sure if my new "box" is a little deaf, but I am still doing some testing and hope to be able to share from JFK, SFO, SAN and LAX over the next couple of weeks.  I will only be able to take the supplied aerial so not sure of the range, but anything is better than nothing :-)
Mark
dca
I'm in NY now close to JFK & showing currently 67 flights in 'my flights' but only around 6 are being tracked on my screen. Mode S is showing for them all.
Can anyone suggest why they are not showing on the screen?
9 nm south of LGW
Hi DCA
If there isn't a blue globe to the left of the Status column in the grid, then the aircraft isn't broadcasting its position, so it won't appear on the map.
Unfortunately, the US is behind Europe when it comes to broadcasting position (via ADS-B) so only a selection of airlines/aircraft types will show on the map.
dca
That certainly seems to be the case- disappointingly! Thanks Rod.
Dave
9 nm south of LGW
QF1
I had that problem when I was there in August last year, Dave.  I was staying downtown but had a great view and could see La Guardia and approaches to JFK.  The only way to really identify aircraft using Mode S was if they had altitude showing and even that is a little "hit and miss".  I will be arr JFK on Asiana on Thu night.
Mark
Jetcos
Same issue I have in Toronto, only the aircraft that are typically heading to and from Europe show up. Newer aircraft are showing up as they are delivered (ie: COA, Westjet has 1).
I added a screenshot from last Sunday.  So we do get some aircraft, far cry from my visits to Europe.
Steve
Steve Cos
CYYZ Toronto,Canada
dca
Thanks for all your comments! It has been interesting watching the traffic here live but only ever around 10% has broadcast position & yes most of those have been UK, European & Asian carriers. Lets hope the US catch up soon, they're missing out here! Enjoy your visit Mark.
Brgds,
Dave
9 nm south of LGW
Don't know if it's from QF1 or DCA, but returns are coming in nicely on the network from JFK at the moment.
Thanks!
dca
You may have a combination of the 2 but its been better this evening, I've been on since around 1730L, 2230z.
Thanks for the feedback Rod. It will be on again from the same time tomorrow, then I'm back here again the week after next.
Brgds,
Dave
9 nm south of LGW
