Lost map....
Started by dl1812, January 09, 2009, 02:43:14 PM
dl1812
Hiya,
I keep "losing" the Map if I go into another programme for a while.
In its place is, for example, part of the Excel spreadsheet I was working on before I switched back to AirNav.
I can get the Map back by going to Map_Open Map_Default, but it's getting a bit frustrating....
I uninstalled AirNav from Programs and and re-installed it on C: Drive after reading these Forums, but I can't find reference to this problem on the forums (unless of course I missed it).
I'm running XP Professional; is this a known bug, or whatever ?
Deadcalm
Several of us have reported a problem where RadarBox cannot be recovered from a minimised state - don't know if there's a connection...
DC
dl1812
It's not minimised, , it's just in the backgound.
When I come back to it, everything is there but the Map - it's as though the Map has become a "window" to the Application behind it !
Very strange....
Still lovin' it, though :o)
Never heard this before, can you send us some details about the computer you using such Operating System, any special software and screen resolution.
Deadcalm
Having given it some thought, artifacts remaining on screen having moved an overlaid application are usually a "feature" of the video card - have you tried updating drivers or re-installing your existing video driver?
DC
dl1812
Good call DC - seems to have cleared it up. Thanks a lot.
DL
