Polar diagram - inclusion criteria?
Started by Fenris, January 12, 2009, 03:05:12 PM
Fenris
A quick question about the polar diagram.
How many messages from a given aircraft are required to include that position as within the polar diagram limits? Or indeed some other requirement like several positions in close proximity to each other?
I've seen a couple of cases where a short, but noticeable track appeared from a non-network flight and the polar diagram did not expand to include that position at its edge.
This maybe entirely sensible, I'm just trying to get a grasp of how the decision is made.
peteeds
I have been running a test here today, I have had SBS Plotter running in the background most of the day & i'm baffled by the results, Polar diagram from RB shows a reasonable all round coverage, polar diagram from SBS plotter shows no coverage to the west at all but all other directions pretty much the same, is this just a glitch in the software or is rb polar diagram better than sbs. odd as the signals are comming from the same antenna. any ideas.
cheers Peteeds.
If I remember correctly, SBS Plotter can be set to draw a diagram of coverage at different heights?  RB includes all aircraft, rather than specific heights.
peteeds
Hy allocator, tnx for the quick reply, Just checked again & sbs set for all hights so I assume the diagram should be pretty much the same on both but rb shows a much better coverage so maybe it is better. Just checked your flag on the map & it seems we are not that far apart just offa's dyke between us ???
Cheers Peteeds.
Did you reset/clear the RB polar diagram before starting your test?
peteeds
Hy Tarbat, yep started both systems from scratch, will have another go tomorrow & see what comes up. will keep you posted.
Cheers Peteeds
Quote from: peteeds on January 12, 2009, 09:04:52 PM
Cheers Peteeds.
Yes, it looks like it's you and me guarding the western approaches :-)
