Map saved
Started by Erich, December 04, 2018, 03:50:05 PM
Erich
Hello Alan
Thanks for the guy to save.
I always finish in the upper left corner. But when restarting does not come the stored
Or used card but always the world map. Where is my mistake.
I already tried everything. I've been working with AirNav for 10 years but since 6.00.001
I can not handle it certainly with my settings.
LG Erich Austria
Hi Erich
I have V6.01 as well and the map always opens where I have it before closing down.
I can only presume that yours has been saved using Map/Set Map to/World.  Try using another of the preset maps to see if it closes down and opens to that map and if so you know the issue.  You can then save your own map named Austria and then set the map to it using Map/Set Map to/Austria
