Map saved
Started by Erich, December 04, 2018, 04:44:54 PM
Erich
Hello Alan!
Even this attempt did not help you can delete cards to start over. Sit already days with the maps
in front of the PC without success. To despair it always comes
Again, the world map. But THANK YOU Alan for the guy
LG Erich
#1
Maybe someone else can come up with a reason why it opens at the world map instead of the one it is at when it closes down
Don't start a new reply with every answer.  Continue on the same thread.
Erich,
Set your map to Austria or your local area. Before closing down do 2 things :
Go into Map>Save Map as (Austria or your area).
Go into Window>Record Desktop.
Hopefully, when you open up your correct map should come on automatically.
Erich
Hello Runway 31!
Thanks for the type but unfortunately without success synonymous with Windows Record not otherwise tried at least 100 times in all
possible possibilities unfortunately always comes back
World map to the opening then I have to open on Map
then open my saved map.
Will try my file externally to spokes and then
AirNav new instalieren.Danke but for the help.
Erich
Hello  EK01
#5
Sorry I cant help Erich
Erich
Further suggestions or possibilities for the
Saving the last card are welcome.
I will not give up until I get my card
save.
LG Erich
Erich
Hello Alan!
Unfortunately, AirNav Support after two times
Request no answer. Bad service at ANRB
Thank you Alan for your efforts
LG Erich
Erich
Pass me your tickets ID from the auto response, if you didn't receive an automatic response they have not received your query.  They should reply within 24 hours.
Erich
Alan!
Last mail was not an ID number today
the others are already deleted unfortunately !!!
Send me your email address used to contact support and I will get them to look for your contact emails,  use PM or email if required
Erich
Hello Alan!
My mail address [email protected]
My Skype Address erich.keplinger2
Sanke Alan for the help
Support emailed Erich
Hi Erich,
There are no support queries related to your map issues in our support system, we do see other replies to your other emails regarding network etc.. 2 months ago. If you don't get a ticket id then please submit via the website next time.
Regarding your issue, are you running with admin or is your username restricted. RadarBox writes to the registry for the map data so if cannot access the registry (due to not being admin) it won't be able to update it.
