Hex code updates
Started by GreekSpy2001, January 23, 2009, 11:10:55 AM
Jollygreen
Is there anyway that we will be able to update those Hex codes that have missing data, apart from doing it manually that is
#16
Quote from: Jollygreen on January 29, 2009, 04:01:09 PMIs there anyway that we will be able to update those Hex codes that have missing data, apart from doing it manually that is
Yes, if you have SQL skills and a decent SQLite database tool - http://www.airnavsystems.com/forum/index.php?topic=1489.msg11716#msg11716    I'm doing this daily at the moment,
Or wait for Airnav to fix the problem, and then use the Populate function in Radarbox to catch-up.
Fenris
Quote from: AirNav Support on January 29, 2009, 03:15:41 PM
They are not, we are still awaiting the GAS link up to be updated.
I assume the interface between GAS and the new server is unchanged, do you understand why it has broken? Asking purely for information rather than as a hurry up!
Interface is the same, as the server is changed, GAS need to authorise its connection. Hence why we are trying to contact them and get it rectified asp.
Fenris
Quote from: AirNav Support on January 29, 2009, 09:46:10 PM
Oh I see, that sort of problem!
Thanks for the answer.
Airnav, did you try contacting GAS via. cessna24v on the Kinetic forum?  Gary has been active on that forum today.
We did sent him a message via the forum earlier on.
abrad41
Airnav,
Do we have any news on this, as the populate fuction is still not working right.
Quote from: abrad41 on January 31, 2009, 12:13:44 PM
Airnav,
It's working fine for me - what isn't working for you?
abrad41
The last time I tried Populating all it was putting in the Navdata was Reg & ...
Have not tried it laterly because of this, I will try again later.
As you can see above Allocator, There was a problem with gas and Airnav Support have not confirmed it has been sorted.
It's populating, but some of the aircraft seem to have poor quality data.  Not sure if this is a GAS or Airnav problem.  Here's the last 100 aircraft populated in my Radarbox.
Yes, good point tarbat, doesn't look like it's quite there yet.
And here's what the same 102 aircraft look like after running their ModeS codes through GAS populate.  Not perfect, but a lot cleaner than the Airnav data.
Think I'll stick with getting my aircraft direct from GAS for the moment.
Tramline
Hi, is there a publication online which lists Airline Fleets and Military Hex Codes as a 'list' rather than individual hex codes as per Airframes.org.
For example if I wanted Hex codes say for AF B777's where can these be found as a list.
I know this is probably an amateur question but only through this forum did I find out RAF were 43C* and USAF AE0* etc.
Once again, thanks to all those who impart their knowledge on this excellent forum.
Thanks in advance
Located 2 miles South of LHR.
#29
Airline Fleets yes - airframes.org
Use the Airlines option from the menu on the left, put the code in the search box e.g. AFR, then click on AFR in the table.
You have to click on each aircraft to get the hex code, but often then run as a block sequence.
For military aircraft, not sure.
