Hex code updates
Started by GreekSpy2001, January 23, 2009, 11:10:55 AM
In fact, airframes.org can list some military "fleets" too.
Tramline
Thanks Allocator, I've done that and I get a display as below
F-GSPA Boeing 777-228ER B772 29002 129 AFR 1998 1998-03-27  active
I get the hex code by clicking on each indiviual A/c but I was wondering if the hex codes were listed in just like a reg, i.e in another visible column?
Perhaps I'm just being pedantic, I'm looking to be able to 'cut and paste' into
my RB Alerts.
Anyone know where the hexcode military listings maybe found?
Located 2 miles South of LHR.
Not quite as simple as it would seem!
You could try reading through this thread on the other forum.  You can see how much detective work is needed to find the military code blocks :-)
http://www.kinetic-avionics.co.uk/forums/viewtopic.php?t=4023&postdays=0&postorder=asc&start=0
A useful resource for military aircraft is http://www.live-military-mode-s.eu/
You'll need to get a fee logon to use, and preferably share your RB logs with the site.
GreekSpy2001
This Hex only just been picked up A54EDF.  Both Airframes and GAS identfy this as a Be300 N441FP.  I have clicked on the hex in my flights but it has not updated.  So is this service back up and running?
Graham
jgrloit
Try turning off then back on the process Hardware flights, while you have an InterNet connection.
It seems that the Airnav RB database takes the info request from a remote system as the prompt to check with GAS, for an ID that it is unaware of.
It does NOT record which system initiated the request, but will feed the data back on your next NEW seem info request.
Based in Hexham - Tyne Valley
#36
A54EDF populated in MyLog okay last night at around 11pm.  It's got the "..." in short type, so it was definately populated from the Airnav server.
Did you have network aircraft turned on at the time?  If so, this could be the known problem with aircraft transitioning from network to local not getting their registration details.
GreekSpy2001
Nope rarely have the Network feature turned on. Seems there it is something else in my setup not quite right
Graham
