changeover to radarbox
Started by liammccarthy, January 23, 2009, 12:05:08 PM
liammccarthy
hi everyone, as a user of the sbs-1, Iwish to change over to the radarbox due mainly to the opportunity to be able to see aircraft tracked worldwide My Question is, as i am operating  a laptop with mobile broadband ,wil that enable me to see flights  over other countries or do i have to have home broadband? any advice or help would be great. I am reasonally happy with my sbs but have found it akward to get addons to it. thanks liam
viking9
Hi Liam,
Welcome to the group. I frequently use RB with my laptop and Vodaphone mobile broadband dongle. Like a mobile phone, results depend on location.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
rogerl
Laptop and mobile broadband work fine with the network for me with the radarbox.
If you already have an sbs-1 you might want to look at adding Planeplotter for network traffic,  certainly within the UK that gives me more traffic than the radarbox network (and in real time).
liammccarthy
hi, thanks for your reply can you tell me more about planespotter. liam
viking9
You can learn all about PlanePlotter and download a trial copy at this address:
http://www.coaa.co.uk/planeplotter.htm
Tom
Tom
15 miles SE of EGUN
RadarBox Network has now usually 200 permanent sharing stations.
You can check a real-time network sharer locations at:
http://www.airnavsystems.com/radarbox/network.php
liammccarthy
thanks it looks like that is what i want to see with the radarbox. wil it work with my existing external antenna?
besty
If you have a bnc connector you'd need an adapter to sma but you can get them quite easily.
http://www.maplin.co.uk/module.aspx?moduleno=32015
Stuart
Terry
Yes is the answer,as Stuart rightly says you will need an SMA to BNC connector which are available from Maplins for around £2-50.
      Regards Terry.
liammccarthy
Terry
No problem,this is what the hobby is all about,and the forums of course.I`m using the BS1100 with the RB,I have an SBS1 but don`t use it any more but still use the antenna with the RB,and it woks very well indeed.
            Regards Terry.
