Populate Query
Started by Col, February 02, 2009, 09:08:10 PM
Col
I have had the RB for a couple of weeks now and I am really enjoying it. This obviously coincides with the server problems so I am not 100% sure how it is all meant to work when it is all working properly.
When I go into MyLog I obviously have a number of codes which do not have tie ups. I then go to Populate and the message says that I have a number of codes have been updated and that MyLog will be refreshed when complete. The trouble is that the number being updated is constantly increasing - the number now stands at over 1,000.
The message at the bottom right of the main screen says that it is processing 1,000+ photo/info requests - I assume that this is not correct but is it related to the server problems or have I set up the system incorrectly?
Colin
Colin
Wokingham, Berkshire
#1
This may be tied-in to the ongoing autopopulate problems following the server rebuilds.  Maybe Airnav can clarify if autopopulate is now working fully.
1,000 unknowns sounds high, I currently have 189 unknowns, which is also quite high compared to my past experience.  This might suggest that there is still an autopopulate problem.
If its not a problem at the Airnav end, then it my be your firewall that's blocking updates.  Are ANY aircraft populated with Registration and photos?
gzerovti
I had 320 when I clicked onto auto populate last night.
Mine has increased also over the last few days.
Terry
G0VTI - On the flight path to EGNM
Col
If I click on an item in the network screen which has no reg details it does populate in most cases although type is often left as "..." so I think that the firewall is not a problem.
Obviously the fact that I am a new user may explain why there is so many to populate.
Colin
Colin, yes, sounds like your firewall is NOT the problem.  I would guess that auto-populate still has some problems on the new Airnav server then.
dl1812
Thanks Guys,
That's answered my query too - 500 and rising !
DL
JStobbie
I have 600+ plus now .... I love the product having been an SBS person previously but any ideas as to when this will be sorted ?
Jollygreen
I did mine last night and got a count of 1200+, took for ever. Let's hope it is sorted soon
It should be ok now, can you confirm it processing them and populating?
EGNXR
sorry Airnav I still have same problem. downloading photos and losing data
Based in Derby 5Nm NW of EGNX
Col
HI
I have just run the populate function again (on 1174 aircraft!) and having waited for the quite a while for them to be processed I then went back into MyLog and went to populate and I still had all 1174 to process. In other words nothing has changed.
Colin
Minou
#11
Quote from: AirNav Support on February 05, 2009, 08:38:56 PM
I have got the same problem. I have noticed that when the populate task has been processed , it just renews my Photo files almost completly. Almost all the  photos that were already there were replaced by the same photo. When I press populate again, the process starts all over again. Again it almost completly renews my Photo files.
gzerovti
I had 370 to populate last night.
It took a while and when I checked later it was still at 370.
Terry
besty
Populated my missing aircraft last night, still missing. I've just populated a blank aircraft on my log got the photo and the registration, ... for type and no other details.
Bat 21
Things look a bit better this morning.........
My new aircraft are downloading photo's and all info.... (was just getting photo and type before today).
B21
