Vista Problem ANRB stopped working
Started by bexil, February 05, 2009, 04:25:07 PM
bexil
Hi all, Just recently purchased RadarBox  and installed program as suggested for Vista, but while closing other programs in use on my computer i get the message (ANRB.exe has stopped working). doesnt happen all the time just annoying when it does, has anyone else encountered this problem.
Im running a AMD 64bit Dual Core Processor 4200+ 2.20GHz and 4Gb of Ram and 32 bit Vista Operating System
30 Mls from EGKA
22 Mls from EGMD
35 Mls from EGKK
Steve
First thing to check.  Are you running the latest 2009 (v2.0) version of the Radarbox software?
bexil
Hi Thanks for the reply
Yes I am using AirNav RadarBox 2009
Software version 2.01 2008/08/20 20:03
Firmware Verion 02.03.1
30 Mls from EGKA
22 Mls from EGMD
35 Mls from EGKK
Steve
dca
Hi Bexil, Happens to me frequently, I'm running 2009 on 64bit vista. Must be a South East thing! It is very annoying though, particularly as I like to leave it running for long periods, overnight etc.
9 nm south of LGW
Fenris
Quote from: dca on February 05, 2009, 09:33:37 PM
I had an instance of this with 32 bit Vista last weekend, it was essentially as if the driver had lost communications with the hardware, it required the USB lead to be cycled in the PC and then it sprang to life again.
bexil
Glad to know its not just me, i have set the program to run as administrator and ran vista verifier to check if i have any unsigned drivers causing problems. doesn't do it with every program just seems to be random, will have to see if new software release picks this up.
I also run the SBS from time to time and dont have problems with that
30 Mls from EGKA
22 Mls from EGMD
35 Mls from EGKK
Steve
Jollygreen
I have had my ANRB running since 6:00 am this morning and all of a sudden I keep getting a "Hardware Disconnected" message. This has happened 5 time now in the last two hours.
BTW running it on Windows XP
Any suggestions?
EGNXR
I had similar problem. I disabled the power save mode and sleep mode.
GO TO Control Panel > Power Options > Edit Plan Settings:-
Change > Turn off display in plugged in to NEVER
Change > Computer to Sleep plugged in to NEVER
The settings for Battery Power I left at default
Then Save Changes
This cured the problem I had leaving it running 24/7
Hope this helps John
Based in Derby 5Nm NW of EGNX
bexil
Hi all
I have  noticed from some of the replies that you are getting a hardware "disconnected message" not sure if this the same thing I am refering to, what I actually get is a pop up box with "ANRB.exe has stopped working" and the whole AirNav program has shutdown and has to be restarted and it is only
happens when closing down another program like Internet Explorer
30 Mls from EGKA
22 Mls from EGMD
35 Mls from EGKK
Steve
