Author Topic: Help with FTP Upload Please  (Read 17471 times)
jonjorobb
« on: February 17, 2009, 01:40:37 PM »
Hi all, I'm currently trying to set up my Radarbox feed onto my friends' website, so far, between us, we've set it up so it should work, sadly, it doesn't.
Here's the settings we're using...username and password are different to the real thing, but otherwise it's right.
Username: USERNAMEHERE
Password: PASSWORDHERE
Host: ukmil.org.uk
Port: 21
Folder: /httpdocs/radarbox/
This is on a Windows 2003 server, using Plesk and IIS. The FTP account has full read/write permissions, with the home directory set at /httpdocs/
Can anyone spot any issues from that, or do you need more?
Cheers,
Jonjo
viking9
    • Aircraft Photography
Re: Help with FTP Upload Please
« Reply #1 on: February 17, 2009, 01:50:05 PM »
What problem have you got? Getting it to the server or displaying it on a webpage?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
« Reply #2 on: February 17, 2009, 02:02:32 PM »
How are you entering the folder name in Radarbox?  I found that I had to leave off the leading and trailing slashes - so htdocs/shot in my case, or httpdocs/radarbox in your case.
jonjorobb
« Reply #3 on: February 17, 2009, 04:35:32 PM »
ive tried the folder suggestion, no luck. Our problem is getting it to the server.
Thanks,
Jonjo
viking9
« Reply #4 on: February 17, 2009, 04:59:43 PM »
Jonjo,
The host name does not look right to me. That is your friend's domain name. You need to put the name of the server that hosts that domain in the 'Host' box.
Tom
Tom
15 miles SE of EGUN
« Reply #5 on: February 17, 2009, 05:21:50 PM »
Dont' know what else to suggest.  Maybe you need to put ftp in front of ukmil.org.uk, to give ftp.ukmil.org.uk.
Attached picture shows what my ftp upload setup looks like.
Maybe find any error messages being issued when you're trying to upload.
« Reply #6 on: February 17, 2009, 07:35:34 PM »
Jonjo,
Have you checked out the FAQ here:
http://www.airnavsystems.com/forum/index.php?topic=1385.0
I suggest that you use an FTP program to connect to your web host and actually see the folder structure on the server.  I use WSFTP Pro, but there are free FTP programs out there.
If you can't FTP to the host, then this might be a clue that you are doing something wrong.  If you can FTP and you can see the scree shot where you think that it should be, then you are getting close :-)
If you look at http://ukmil.org.uk/radarbox/ which is where you are trying to load the screen shot to, there are files there, but not the RadarBox file.
jonjorobb
« Reply #7 on: February 18, 2009, 09:55:38 AM »
I thankyou all, we did finally get it working (please dont ask me how!)
http://ukmil.org.uk/radarbox/RadarBoxScreenShot.gif
Thanks,
Jonjo
« Reply #8 on: February 18, 2009, 12:36:49 PM »
Jonjo,
I still can't see your screen shot at that address.  I see:
lindex.php
LM_REPORT.rtf
and that is all.
jonjorobb
« Reply #9 on: February 18, 2009, 03:12:51 PM »
yes, sorry. its been took off temporarly, but we did get it working.
Thanks,
Jonjo
