Author Topic: AirNav RadarBox 2007 - Version 1.2 (Patch Beta 2) Post 2:  (Read 122736 times)
Re: AirNav RadarBox 2007 - Version 1.2 (Patch Beta 2) Post 2:
« Reply #75 on: September 23, 2007, 04:29:31 PM »
hi Air Nav
i operate in 3 computer ...i have download new patch ..NOTING not work..i think 710 euro for one program that work or it does not work badly are too many. .cosa I must make? Sorry for my english...they are a lot  sad and angry
Davis,
I do worry that if you can't get RadarBox to work on 3 computers, then you must have done something wrong :-(
It is highly unlikey that it will not work on all three.  Maybe you have made the same mistake with each installation?
ANRB13
Driver 2.2.4.0
Firmware version 1.01.0
« Last Edit: September 23, 2007, 04:33:10 PM by Allocator »
davis
  • RANGE
« Reply #76 on: September 23, 2007, 04:37:02 PM »
Hi Allocator
I have made all what air nav it has said to make to me I have dawnload new patch and new drive. .wath I must still make?
« Reply #77 on: September 23, 2007, 04:52:32 PM »
Hi Allocator
Davis,
Are you running Xp or VISTA - if it is VISTA then I can't help you.
 - You are correct about the Firmware upgrade.  It happens very quickly and the window has to be closed by using the red cross.
- Reading back through your posts, you believe that you have installed everything OK and upgraded to the Beta version with the Firmware upgrade.
- Your problem is that only the power light shows on the RB "box"?
- Can you see the AirNav RadarBox in the Universal Serial Bus controllers section of the Device Manager as shown by my screen shots at the start of this thread?
All the best
davis
  • RANGE
« Reply #78 on: September 23, 2007, 04:54:27 PM »
i have normal XP no vista
« Reply #79 on: September 23, 2007, 05:19:19 PM »
Thanks Davis,
Do you have answers to the other questions I posted in my last post?
davis
  • RANGE
« Reply #80 on: September 23, 2007, 06:16:19 PM »
YES  for all the questions  i have drive 2.2.4.0 upgrade is 0.91.0  up version 1.01.2.. now wen i start with  ANRB.exe interface appare but i put  email e password but not go..i put user name from original CD with pass but not go ..one problem after other ..
Didimon
« Reply #81 on: September 23, 2007, 06:38:35 PM »
The only way to get people happy again is to release an official version with no crap within a few days MAXIMUM.....
I'm totally fed up with the circles we are talking in here with no result....
It's very nice that it's working for a lot of people but don't forget the few which keep on having problems... also these people should have a working product without any failures.
« Reply #82 on: September 23, 2007, 06:40:14 PM »
OK Davis, so your problem is with starting RadarBox as the startup window will not accept your username and password off the CD?
The Username and Password are on the CD, you do not put your email address in the start window.
User name should be something like:
PGANRB100***
and Password:
1757*****
Make sure you type both of these in rather than allowing RB to "remember" the password from the last time (as you might have entered this incorrectly).
What happens?
davis
  • RANGE
« Reply #83 on: September 23, 2007, 06:44:40 PM »
HI Didimon You are very gently..I work with the computers from 15 years I'm pilot, but a thus problematic program I have not never seen it.
« Reply #84 on: September 23, 2007, 06:45:13 PM »
Didimon,
I've read back through your posts, and I think that your problem is that RB runs OK, but shuts down after a few minutes.  The only time I've had this happen is when I've had "Share Flight Data" selected in Preferences and I've been running without an Internet connection or my Internet connection has failed.
I'll read back again through your posts, because I might have got this wrong.
davis
  • RANGE
« Reply #85 on: September 23, 2007, 06:51:54 PM »
HI Allocator  ..confirm user of CD is PGARNB1002XX
pass 175756XXX   wryte like you see.correct ..i flag' remember ' but not go..
« Reply #86 on: September 23, 2007, 06:57:10 PM »
OK davis,  have you tried it without the "remember" box ticked?
What happens when the user name and password are not accepted?  Does RB just shut down?
AirNav Support, no idea why this won't run if davis is using the correct username and password.
« Last Edit: September 23, 2007, 06:59:02 PM by Allocator »
« Reply #87 on: September 23, 2007, 07:06:04 PM »
davis,
you did mean PGANRB as the start of your username , NOT PGARNB didn't you?
davis
  • RANGE
« Reply #88 on: September 23, 2007, 07:06:41 PM »
YES i not flag REMEMBER is freeze e i must make computer off .non possible off with red X
davis
  • RANGE
« Reply #89 on: September 23, 2007, 07:12:43 PM »
PGARNBXXXX is username written  in original CD..
