Author Topic: Connecting the Co-ax cable to the Radar-Box  (Read 4631 times)
Johnn
  • Y'ello
« on: February 24, 2009, 04:23:02 PM »
Hi there
Someone had told me that I need to have a 'patch-lead' for one thing or another to reduce the strain or something? anyone shed some light on what this means please?.
I was planning on having a 15ft pole with the cable going from the antenna to the RB.
John
Johnn -
Re: Connecting the Co-ax cable to the Radar-Box
« Reply #1 on: February 24, 2009, 04:27:40 PM »
Hi John, rather than having a stiff, heavy co-ax lead connected to the RB, it is preferable to use a lightweight (eg RG-174) short (I like 18"/450mm) "patch" lead with an SMA plug to connect to the RB, and my choice is N-type in-line connectors to connect antenna downlead to the RG-174 one.
A source is http://www.garex.co.uk/patch%20leads/patch%20leads.htm
« Last Edit: February 24, 2009, 06:23:12 PM by CoastGuardJon »
    • Rod's RadarBox Downloads
« Reply #2 on: February 24, 2009, 05:50:59 PM »
This is the fly-lead on mine:
anorak
« Reply #3 on: February 24, 2009, 06:17:30 PM »
Hi John Give Henry Westlake a ring
 http://whwestlake.110mb.com/
Very good and quick service.
Dave.
Dave. Exmoor, North Devon.
Johnn
  • Y'ello
« Reply #4 on: February 24, 2009, 09:02:26 PM »
Okay, Thanks for help all!
Johnn -
GRIMREAPER
rodbearden Connecting the Co-ax cable to the Radar-Box
« Reply #5 on: March 07, 2010, 08:58:04 PM »
FAO Rodbearden
Where did you get your patch lead and what connectors  and cable do i ask for.
G
« Reply #6 on: March 07, 2010, 10:05:43 PM »
Hi Grim
My patch lead came with the external aerial and W103 cable from AirBand-Online here: http://www.airbandonline.co.uk/kapl_sbs1_aerial.htm
Note that the RadarBox version costs an extra £5.00, which is presumably the cost of the patch lead.
It's all still going strong after 2 years :-))
« Last Edit: March 07, 2010, 10:08:06 PM by RodBearden »
