Author Topic: Upgraded to new beta upgrade i think??  (Read 7186 times)
spotter70
« on: September 17, 2007, 06:47:04 PM »
Hello
I have followed the instructions for download of new beta.
I have attached a screenshot as the screen is now in awider view than before.
thing is that i thought the picture viewer had been disabled but mine is still running.
It has been running with network on for 25mins without timeout but i will monitor the situation.
I don`t think the upgrade has worked but something seems to be .
I did manage to do the driver update maybe that has done the trick.
Regards Spotter70
[attachment deleted by admin]
Re: Upgraded to new beta upgrade i think??
« Reply #1 on: September 17, 2007, 07:09:54 PM »
Hello
Regards Spotter70
Well done Spotter 70,
If you go to Help/About, what version of ANRB does it say you are running?  It should say ANRB12.  If you get the Vertical Tracking Window below the map window when you run RB, then you have the new version :-)
Also, in Windows, if you go to Control Panel/System/Hardware/Device Manager/Universal Serial Bus Controllers and right click on AirNav RadarBox and select Properties, you should be able to see the Driver version - 2.2.4.0
It's the photo DOWNLOAD that is disabled in the Beta12 version, not the photo DISPLAY.  This means that you will see pictures that RB has downloaded to your hard drive previously, but no new photos will be downloaded.
spotter70
« Reply #2 on: September 17, 2007, 07:21:10 PM »
Does not seemed to have worked then
i have Driver 2.0.0.0
also ANRB11
But something is definately different as the fields are on the other side and the screen larger .
Don`t really know what has happened here .
My poerating system is Vista home premium Intel Duo core 2 Processor T5500
1.66Ghz 1GB DDR2 Sdram HDD 100gb
Just thought i would mention it it may prick up a few ears
Spotter70
spotter70
« Reply #3 on: September 17, 2007, 08:07:16 PM »
I spoke too soon it timed out after 1hr 25mins blue screen and shutdown.
I will not try again will wait patiently for the upgrade.
Spotter70
« Reply #4 on: September 17, 2007, 08:19:11 PM »
Hi spotter70,
You driver is not the latest and neither is your software which explains why it does not work fully. This points towards not extracting the files to the correct directory.
Read through the troubleshooting post in the earlier post.
