Maps problem (fix)
Started by mt007, March 08, 2009, 07:34:19 PM
mt007
Hi guys,
i need you help.
I open my maps and when i choose FIX i see error near to FIX names, apear a litle square near to words, names.
See image below.
Any idea?
Thx.
Regards.
Hi Miguel
I think this may be a font problem - try changing your font (Files...Preferences) to Verdana and see what happens.
mt007
#2
Hi ROd,
i change it and the callsign change but FIX too, but a square mantein.
Hmmm... sorry, Miguel, no more ideas :-(
Rod!
Starburstdave
Hi Miguel
Goto  Map>Aviation signs>Station Labels there are 3 options : Identifier,Name & Box. Make sure that Box is not ticked and this should remove the box from around the station name
Hope this helps
Dave
viking9
Dave,
It's not the box around the station labels Miguel is complaining about. If you look very carefully you will see a little square at the end of the waypoint names. I think a change of typeface may cure it.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Starburstdave
Tom
Sorry about that I didn't really notice that until I looked again. Other than what has already been suggested I can't help
Dave
jgrloit
Just try zooming in, and I think you may find that the boxes change to the runway layouts for the airfields in question.
I have just checked this with the batch in North Yorks - having viewed boxes when on a scale that shows England from EGNV to EGPD as the North South range.
When I move the map south I get boxes at EGXD, EGXU UK11, EGXE  Zoom in and the runway layouts appear.
Based in Hexham - Tyne Valley
viking9
Quote from: jgrloit on March 08, 2009, 10:04:39 PM
It's the little boxes at the end of the waypoint names he's complaining about, not the one's around the airport labels.
Tom
15 miles SE of EGUN
mt007
Guys see my last image below.
Regards.
jgrloit
I am not getting the problem here, but I am using Arial and Western Script.
What are you using, as in some script & Font sets the Block is used to indicate an unprintable character.
Could your sript be showing a Space character for some reason?
manuel
Hi.
I have the same problem :(
No idea how to remove them!
Also tried other fonts but the small annoying square was there all the time like now.
This is starting to sound like a language setting - can you guys in Portugal try an experiment, and change your Control Panel Regional and Language Options to "English United Kingdom", assuming it's "Portugese (Portugal)" at the moment.
While this would not be an ideal solution, if it works it will give AirNav somethng to work on!
manuel
Tried to change the language setting as suggested: no effect. the square sits there as a rock!
Out of ideas again! Sorry!
