Author Topic: Radarbox does not receive signals!  (Read 7196 times)
LiveATC
« on: September 19, 2007, 11:59:41 AM »
 Antenna Wimo GP-1090 antenna amplifier LNA 1090A-TM cable RG-11 of 45 meters, Bias-T KU BT 271N. The antenna is on a roof direct radio visibility. Distance from the airport of 7 kilometers
LiveATC
Re: Radarbox does not receive signals!
« Reply #1 on: September 19, 2007, 01:17:06 PM »
Has changed USB port, the signal is!
« Reply #2 on: September 19, 2007, 02:10:44 PM »
What happens with the default antenna, did it work with that?
Does the RadarBox 2007 software confirm that RadarBox is connected?
doro
« Reply #3 on: September 22, 2007, 03:15:42 PM »
Get rid of the amplifier, you do not need that with that antenna (I have it too) and good cable. Ronald
flightchecker
« Reply #4 on: September 22, 2007, 05:34:20 PM »
Fully agree on that, LiveAtc and Ron,
provided, the feeder cable does not exeed ~10 to 12 meter in lenght. Also take care of proper connectors.
Karl
