scanner interference
Started by davjhedges, March 09, 2009, 05:18:54 PM
davjhedges
rb working fine,problem occurs when my pc is on,it is creating a lot of interference on my scanner when listening to the airband,despite moving pc base unit 8 feet from scanner.scanner is gre 295,when pc is off reception is fine .any suggestions please.thx.
Lou
Hi you need an external aerial for the scanner, your computer is a box with millions of switches all going of at the same time so massive interference.I had the same problem until I got a decent outdoor aerial. Regards Lou
davjhedges
Is your computer in a metal case or plastic?
waddington1
Hi are you using a CRT monitor, I get loads of problems with my scanner when I have my CRT on.  Most of the time I use a Laptop with no problems at all.
Stu
jgrloit
THere were a few, ex dealing room, metal cased monitors sold at radio rallies a couple of years ago.
I think they handled VGA, but you had to make up a cable.
Size was about 14 inch, but you could put them side by side and they did not create cross unit interference.
Very little RF output either.
Based in Hexham - Tyne Valley
davjhedges
thx for all your replies,pc is in metal case,and i am using 2 lcd monitors for rb.since my post i have put the scanner in a small metal box wrapped in anti static bags and bubblewrap seems to have done the trick.
Quote from: davjhedges on March 10, 2009, 05:08:34 PMscanner in a small metal box wrapped in anti static bags and bubblewrap seems to have done the trick.
Amazing!
