Drop down lists
Started by jgrloit, March 10, 2009, 02:16:32 PM
jgrloit
Is there any way of cleaning duplicated from the drop down lists of Airports entered, especially in the Weather / Get Weather toolbar.
Also -> development should the various toolbars be floating, so that users can move them around within the toolbat area on the top of the screen?
The Weather toolbar does reposition itself when you minimise then maximise the view.
I minimise then move the display to a second monitor, then maximise....  the Toolbat alignment gets changed by this.
Based in Hexham - Tyne Valley
There's an option in Preferences to clear the drop-down lists - but NOT the weather one.  Or you can use Registry Editor to update the lists.
jgrloit
Thanks - It did clear the Weather one as well, on my system.
Why there were duplicates was the annoying point!!!!
The duplicates will quickly return on the weather one!!
