Author Topic: RB on a Netbook - Preferences Box too big to apply chanhes!!  (Read 17953 times)
Re: RB on a Netbook - Preferences Box too big to apply chanhes!!
« Reply #15 on: March 21, 2009, 01:02:19 PM »
Hmm, The Alert popup is small. How big is it on the netbook?
Tramline
« Reply #16 on: March 21, 2009, 02:29:39 PM »
On my laptop the alert is about 7cm high and 5.5cm wide.  On the netbook, the alert pop up is 6cm high and 5cm high.
It would be a useful feature to custom-size the alert pop up box.
Thanks for checking in AirNav.
Located 2 miles South of LHR.
« Reply #17 on: March 21, 2009, 03:40:16 PM »
But how high/wide is your laptop screen :-)  On my big 22 inch screen, the popup is about one fifth of the height of the screen.  On the laptop, it's about one quarter of the screen height.
What screen resolution are you running?
« Last Edit: March 22, 2009, 09:59:47 AM by Allocator »
pbrstreetgang
« Reply #18 on: July 15, 2009, 11:13:27 PM »
Hey guys.  Im having the same problem and the fixes noted above are not working.  Im running vista and have changed the resolution size and restarted RB.  Any other thoughts?  Very frustrating!
« Reply #19 on: July 16, 2009, 06:44:06 AM »
Hi there,
Just confirm what your problem is here.  What is your screen resolution and what type of PC are you running RadarBox on - is it a Netbook or laptop?
pbrstreetgang
« Reply #20 on: July 17, 2009, 12:51:59 AM »
It is a Toshiba Laptop (15" screen) running vista, 1280x800 res...
I have tried several different resolution settings without any success.  Just so we are on the same page, the problem is that i cant save my changes to "preferences" because the "ok" button is hidden on the bottom border of the window.
-greg
« Reply #21 on: July 17, 2009, 06:52:53 AM »
OK Greg, understand now.  I'm sure that you should be able to see all of the Preferences box with that screen resolution.  Are you using a non-standard larger Windows font?
pbrstreetgang
Preference window hides the "Apply" button
« Reply #22 on: July 17, 2009, 11:45:35 AM »
Nope the fonts are standard.  Im attempting to get a screen shot uploaded that shows this.  Thanks for your help with this!
pbrstreetgang
« Reply #23 on: July 17, 2009, 11:48:36 AM »
Take two!  Smaller Screen shot.
Terre
« Reply #24 on: July 17, 2009, 02:49:31 PM »
you can try to resize the preferences windows with the help of this tool 'ResizeEnable':
http://lifehacker.com/325452/resize-any-window-with-resizableenable
You might have scroll/Move the windows afterwards to access the buttons.
Tallyho
« Reply #25 on: July 17, 2009, 04:21:00 PM »
Looking at your screen shot your display settings font sizes appear not to be set to "Normal".
right click on your desktop background and select properties, select the appearance tab and check what your Font Size is set to...
Normal will paint form as expected, "Large Fonts" or "Extra Large Fonts" will give you problems with forms being oversize like in your example.
Hope this helps
Keith
pbrstreetgang
« Reply #26 on: July 18, 2009, 04:05:42 AM »
Keith, Good job!  That did it.  vista hides the font size menu but i got it now.  Thanks!
