Time outs for Aircraft
Started by kdt1, March 20, 2009, 02:07:33 PM
kdt1
Time outs for Aircraft in my flights.
Support,
Why do I have aircraft that do not time out and stay in the detail
window until I restart a session?
My time out settings are 40/50.
Also columns will not stay sorted.
Are you running RB 2009 v2.0?  Columns not staying sorted was fixed in v2.0.
Tarbat is right, timeouts should always disspear from the MyFlights list as well.
Make sure your using the latest version, I assume you bought recenetly in the US. If so some of the dealers there may have older versions of the software in the box.
kdt1
I have Version 2.01 Purchased from UK Rocket.
#4
Okay, you must have a later version then.  What does it say in HELP ABOUT - mine says ANRB20.
kdt1
Software Version: 2.01
Software Version Date: 2008/08/20 20:03
Firmware Version: 02.03.1
Okay, sorry, I'm out of ideas.
There is a version 2.01. Before somebody asks whats the difference, its just a difference in the install and its on the new CDs, so don't panic.
kdt1,
I have PMed you a email, if you could email that address with some pitcures of it happening, we can get a better idea of whats going on and ask for some debug files.
kdt1
#8
Quote from: tarbat on March 20, 2009, 05:26:52 PM
Thanks for the help Tarbat.
Ok  Support let me have it.  Your Turn.
You need a Picture?  Please
Sorry, let me give it a whirl
kdt1
What's a good screen capture program?
Print screen does not work for me.
viking9
It probably does but you don't know it. It saves the image to the clipboard, so go to 'Paint' click in the centre and press 'Ctrl' and 'V' keys to paste.
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
kdt1
Here is a picture of the remaining Aircraft for this session.
They will not clear until I restart. Note Times and unchecked
Flight data.
kdt1
Two hours after 1st snap shot.
Very strange, not only do they seem to be staying there but unticking the process hardware flights should clean all the aircraft in there straight away. Checking our support folder we haven't a case like this.
1.) First step is to reinstall RadarBox 2009, this is incase of any corruption in the software.
2.) Secondly are the aircraft which never get removed ADS-B aircraft, or are they always Mode-S aircraft? If so is it always Northwest?
3.) Do you have another machine where you can run RB on, this is so we can see whether its just related to a specfic setup or whether it can be replicated which will help us track down the issue.
kdt1
Can I save my DB files, and if so which files do I need to save to keep the software happy?
I think usually Mode-S, I will double check.
No, I have seen Continental and Sun Country so far.
I can change quickly to a different System for testing.
