My Reception suddenly very poor....
Started by bailey_uk, March 20, 2009, 07:22:51 PM
bailey_uk
Hey folks, had my RB for a fair few months now and working brilliant up untill last week.
Hardly any aircraft apearing in MyFlights, and ones that do arent ADS-B, so only 1 aircraft showing on the map every 10 minutes.
From todays performance, its clear that the only ADS-B aircraft shown on my map have to be very close, flying overhead.
Struggling to work out what the problem is.
The only thing I can think of is that the rubber end of the supplied aerial is missing.
I have been using the supplied aerial outdoors, with the metal base disc trapped underneath a slate just below my velux window, which is usually shut, and the supplied coax making its way through the closed widow where it meets.
Anybody have any ideas? Im trying to work a process of elimination but dont have the money at present to by a new antenna or coax.
James
viking9
James,
My guess is that you have crushed the co-ax.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
bailey_uk
I was hoping that that wasnt the case, but its the only thing I can think of too!
Another observation is that a lot of aircraft that are usually showing as ADS-B i.e. EasyJet flights, are showing in MyFlights but not on the map (World symbol in myflights not shown)
GlynH
I don't suppose you have a 'local' RB user who would be kind enough to either;
1. Try his antenna on your box
2. Try his box on your antenna.
Process of elimination really...
If you are really stuck let me know and I could ship you my original RB antenna to try?
I don't use it as I have an external antenna, don't move my box around and the bonus is it wouldn't cost you anything to try...
I would keep your fingers crossed that it is the antenna (or coax) as Tom suggested.
I had a similar problem only weeks into my RB ownership and that turned out to be the box itself...:-(
Kind regards,
-=Glyn=-
If you don't find the issue with the antenna contact support through the ticket system and they will give you details on how to return it and get it fixed/replaced.
bailey_uk
#5
Hi Glyn, have tried making my own antenna out of copper wire today and still have the same results, so id like to take you up on your offer of trying your original antenna to eliminate it from the equation if possible?
I have PM'd you with my details.
Thanks!
James
GlynH
Quote from: bailey_uk on March 29, 2009, 07:58:06 PM
Thanks!
James
Yup..got it & replied.
-=Glyn=-
bailey_uk
UPDATE!
After close inspection to the coaxal contector, it seems that the inner core cable doesnt portrude out further than the white area. It seems flush. Is this how its meant to be?
Earlier today I used a paperclip and had one end held against the inner core and the other end touching the radarbox atenna input and I instantly received 5 filghts.
How do I go about re fixing this connector that seems to be the problem?
My soldering skills are limited, espeially when its so small!
James
jgrloit
I suspect that you have a similar problem to one I had.
Carefully push the outer Coaxial cable into the SMA connector.
The Inner then should protrude by approx 3 mm.
Connect to the Box and Test.
If the above works then the crimp for the connector has failed, the braid has broken - if possible replace the SMA connector, ensuring that the braid is connected and the inner copper protrudes from inner insulation by approx 3 mm.
Based in Hexham - Tyne Valley
bailey_uk
Quote from: jgrloit on April 13, 2009, 02:45:10 PM
Excelllent advice!!!!!!!
Works like a dream now, thank goodness it wasnt a costly solution!
Glynn if your reading this, then you kind offer of sending yours for me to try is no longer needed!
Thanks folks
James
João Gaspar
Hello from Portugal
My radarr box Reception suddenly very poor.
From the last week performance, its clear that the only ADS-B aircraft shown on my map have to be very close, flying overhead.
I tried all the ideas posted here.
João Gaspar, near LAR
