Author Topic: GDBCJ Wrong photo  (Read 4215 times)
EGNXR
GDBCJ Wrong photo
« on: March 22, 2009, 08:01:54 PM »
Hi all,
I have a wrong picture of G-DBCJ if you click on the photo it can not be found on Airliners.net.
1. I have deleted the photo from Photos still comes back
2. Removed photo links in Navdata and deleted photo still comes back.
3. Deleted G-DBCJ from Navdata completly and deleted photo shut down RB and restarted and it. It then re-populated with the same photo.
Any ideas as how I can get rid of this
Cheers John
Based in Derby 5Nm NW of EGNX
Re: GDBCJ Wrong photo
« Reply #1 on: March 22, 2009, 08:30:52 PM »
Most strange, as the correct photo appears on airliners.net
Easy fix for this.
1. go to airliners.net and do a search for G-DBCJ
2. the British Midland A319-131 shows - there are loads of pictures.
3. right click on one of the thumbnails and select "Save as"
4 save the picture to you /Photo directory as:
you can see the directory structure at
http://radarbox.gofreeserve.com/html/downloads.html
5. if you want a second picture, right click on another thumbnail and save this as
G-DBCJ,2/jpg
6. Restart RB and all will be well.
Edit: I've just checked my /Photo directory and I have the correct pictures of G-DBCJ and I assume that they must have auto-populated?
« Last Edit: March 22, 2009, 08:35:46 PM by Allocator »
« Reply #2 on: March 22, 2009, 09:00:27 PM »
Your picture is of N7159N, Mode S Hex code A99240
Your query for aircraft registration N7159N.
Registration Manuf. Model Type   c/n   i/t Selcal ICAO24 Reg / Opr
N7159N   BEECH    V35A   BE35   D-8814   L1P      A99240   R2 AVIATION L L C
http://www.airliners.net/search/photo.search?regsearch=N7159N&distinct_entry=true
« Last Edit: March 22, 2009, 09:02:23 PM by Allocator »
EGNXR
« Reply #3 on: March 22, 2009, 09:25:42 PM »
Thank you Allocator all done
I'll see what happens next time he pops up. That photo downloaded a while back and if you clicked on it it came up on airliners with the correct details for the Airbus but the Beech photo. If you did a search of G-DBCJ it appeared with all the correct pictures. Airliners have corrected there end because it now takes to to an error page. So I don't quite know why it repopulated after I'd deleted it, most strange.
Thanks again Cheers John
