Author Topic: 32 bit.  (Read 5687 times)
vassylad
32 bit.
« on: March 25, 2009, 03:58:11 PM »
Hi guys, my RB is due back with me tomorrow from the manufacturers and  when I asked did they find anything wrong they said no in fact everything was fine well thats strange i said because i was getting time outs with aircraft less then 5 miles away, I then explained I had bought a new laptop with windows vista home premium installed on it, the guy I spoke witth explained that window's vista runs at 64bit but RB runs at the 32bit how do I change that on the laptop please...
Michael
« Last Edit: March 25, 2009, 04:01:17 PM by vassylad »
Blackthorn
Re: 32 bit.
« Reply #1 on: March 25, 2009, 04:13:27 PM »
There are two versions of Vista a 64 bit and 32 bit, my guess is that unless you specified otherwise you will have the standard 32 bit version on your laptop.
Check in control panel/system it will say 32 or 64 bit.
vassylad
Re: 32 bit.
« Reply #2 on: March 25, 2009, 04:39:19 PM »
So does RB run at 32 or 64 bit?, then what could be causing the timout's I wonder.
Michael
PS thanks for the replies
Re: 32 bit.
« Reply #3 on: March 25, 2009, 04:53:36 PM »
ANRB runs on both 32-bit and 64-bit okay.   If you've got 64-bit Vista, the driver installation procedure is more complex - see http://www.airnavsystems.com/forum/index.php?topic=528
« Last Edit: March 25, 2009, 04:56:37 PM by tarbat »
viking9
    • Aircraft Photography
Re: 32 bit.
« Reply #4 on: March 25, 2009, 04:56:32 PM »
I was getting time outs with aircraft less then 5 miles away.
Michael
Michael, what type of antenna are you using and where is it located?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Blackthorn
Re: 32 bit.
« Reply #5 on: March 25, 2009, 06:44:44 PM »
Michael
Likely to be loss of signal, are the timeouts in one particular area?
vassylad
Re: 32 bit.
« Reply #6 on: March 26, 2009, 06:31:35 AM »
Hi guys and thank you for your replies, I invested in the MD-1105-KIT-B mobile aerial with SMA-BNC patch 160mm and although the range was better I still had those ghastly time outs. The time outs usually were at the end of a spike or even within 5 miles of me.
I was reading earlier about not installing RB into its own desiganted folder but within an other that I would give a chosen name to, would this make any difference in the long run and what would that choosen folder be called.
So I am guessing when RB starts to install into a particular C: directory I then have to manually change it?
Thank you Michael
I welcome your replies.
Blackthorn
Re: 32 bit.
« Reply #7 on: March 26, 2009, 01:57:53 PM »
I set mine up to install in to c:airnav
Then I configured my AVG virus scanner not to scan that directory.
Where you install the software should have no ecffect on your signal reception.
