Author Topic: SSE GP1090 aerial  (Read 24336 times)
besty
  • County Durham, Land of the Prince Bishops
SSE GP1090 aerial
« on: April 04, 2009, 10:40:53 AM »
Hi I've just had a new antenna fitted on the chimney stack, thought you might like to see the coverage.
http://farm4.static.flickr.com/3594/3411599974_38be68f98a_o.jpg
It is about 316ft above sea level with fairly clear views around apart from a few house roofs.
1m low loss cable Ecoflex-10 with N connectors
Mast pre-amplifier AS-1090
20m low loss cable Ecoflex-10 with N connectors
AS-1090BT Bias-T for DC-Feed
1m Cable BNC/SMA
Aerial is this
http://www.ssejim.co.uk/26-sseads1090sj.htm
Hope you find this interesting
Stuart
« Last Edit: April 04, 2009, 12:10:48 PM by besty8 »
viking9
    • Aircraft Photography
Re: SSE GP1090 aerial
« Reply #1 on: April 04, 2009, 11:42:15 AM »
Great coverage Stu. Lucky beggar. :o)
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Tailwinds
« Reply #2 on: April 05, 2009, 09:24:59 PM »
1m Cable BNC/SMA
Did you buy the AS-1090 and the Ecoflex-10 seperatly? I see that you can purchase the whole package such as the AS-1090 pre-amp, the AS-1090BT Bias-T DC feed and 10m low loss cable but it's Westflex-103 and not Ecoflex-10. Is Ecoflex-10 more superior?
AllanK
« Reply #3 on: April 06, 2009, 12:22:22 PM »
Stuart,
Can you send me the details/file of the colours used on your map please
Allan
foyledelta
« Reply #4 on: April 06, 2009, 03:30:42 PM »
Stuart,
Allan
yes i like your map colours please send details.
 i putting up a radar-extender and coax westflex-103 but no pre amp, yet.
ITS GOOD TO TALK.
besty
« Reply #5 on: April 06, 2009, 07:08:50 PM »
I originally bought the full kit from Wimo in Germany but the aerial packed up, seeing other threads on the forum I took a gamble on the Aerial and cable to the pre amp. I boughtt the aerial from SSE and the cable from WH Westlakes. The westflex cable is very similar to the ecoflex in size and performance. When the aerial was changed it was wet inside and the cable was too.
So just as well I bought replacemants for both and now I'm very happy with the results.
Stuart
