Map freezing
Started by malc41, April 13, 2009, 09:28:06 PM
malc41
Hi All
I wondered if anybody else has a problem with the map freezing. Everything else seems absolutely fine, but the map just locks and closing it sometimes helps, otherwise its start the program again.
i'm using vista, but never had this problem before, it started two days ago?
Malc
15 Miles East of EGNJ
malc41,
When it occurs does the status show that its downloading the network flights?
There may be slight pause then as it processing and placing 1000 flights back onto the map.
malc41
I don't use network flights just the ones from my airnav box
Malc
