Martin Lynch and Sons as International Distributor
Started by AirNav Development, September 28, 2007, 02:10:05 PM
We are happy to announce that AirNav Systems has selected Martin Lynch and Sons to be AirNav RadarBox Internation Distrbutor. Press Release below.
27th. September 2007 For Immediate Release
Martin Lynch and Sons are pleased to announce their appointment
as international distributor for the AirNav RadarBox.
The exiting AirNav Virtual Radar System has applications across the whole
aviation industry, from monitoring flight movements to alerting staff of the
imminent arrival of a flight, from flight operations through to engineering the
RadarBox is the solution.
The AirNav RadarBox receives Automatic Dependant surveillance Broadcast
(ADB-S) directly from the aircraft and displays the data in a graphical PPI
display on a Windows© PC. The software has a wealth of aviation mapping and
aircraft database facilities which coupled with powerful filtering and email alert
capabilities, plus the option of monitoring flights from other AirNav users via the
internet make this unit indispensable to the aviation industry.
And for the techie's the AirNav RadarBox uses a plug and play USB connection
and derives its power from the PC. The standard software covers 200,000
geographic points including Airports, Runways, VOR, NDB, FIX, Cities, Roads,
Airways, etc. RadarBox has ACARS decoding interface built-in, real time display
of aircraft position, speed, altitude and heading plus automatic retrieval of flight
number, registration, company and aircraft type. Real time weather extensive
data logging and generic XML or PDF reporting are also supported.
Supplied with mini magnetic mount aerial, Windows© software and 1 years
warranty - Available now at £399.96 plus VAT
See also www.virtualradar.co.uk for further information
Note to editor – more information and CD is available which contains a detailed
write-up in .doc and .rtf together with photos in bitmap forms.
If you would like more information please contact 0845 2300 599 or
