Squawk codes and log
Started by daveg4otu, April 26, 2009, 06:57:18 AM
daveg4otu
Is it possible to include Squawk codes in the "My Log" ?
...If so ...how please?
No, the codes are not displayed in MyLog.  This would present a bit of a problem, as aircraft often change their squawk, so which one would you show?
daveg4otu
OK - good point  about the changes - would still be nice to perhaps have the option  to include the  code  in use  on initial contact.For military a/c that is often the only indication of  routing/location etc.
jgrloit
How about first and last as per the positions from the ABS-B.
For Military that could indicate Direction N-S  or S-N, or special area seen in!!!
Based in Hexham - Tyne Valley
jgrloit,
MyLog does already have this for the indvidual flights, Of course 99% of Military flights do not have ADS-B so we don't know there position.
I think that jgrloit means first and last squawk code rather than position.
Quote from: AirNav Support on April 26, 2009, 01:35:25 PMMyLog does already have this for the indvidual flights, Of course 99% of Military flights do not have ADS-B so we don't know there position.
I thought we were talking about squawks ?
kdt1
jgrloit,
Support you need a vacation.
Our mistake, we have no vacation where here 24/7 :)
malc41
Daveg4otu what is the link between squawk and routing with military aircraft?
15 Miles East of EGNJ
daveg4otu
Squawk code are allocated according to a "Plan" which is linked to routings/destinations/origins etc.
So ,as military aircraft routings/positions  are not available via ModeS - butr squawks are.... the  code may  give some indication of  the aircraft's  probable route etc.EG: codes 4530-4542 are used for Aberporth.
malc41
So if squawks are allocated to a flight plan do they change during flight as suggested above?
