Main Menu
Line of sight.
Started by Brimon, May 07, 2009, 01:58:53 PM
Brimon
Where my Radarbox is positioned I have a pretty good field of vision, talking actual vision here not Radarbox, over west central Scotland. But I got so fed up opening & closing the window trying to see aircraft on the fringes that I decided to print off a compass,set it with an actual compass & cut to the extremes of my view out the window.I have taped it to the window-sill & can now see at a glance the bearing etc.
At this point someone will of course come in & tell me that there is a field of vision option on Radarbox LOL
I have not posted this  for any other reason other than to illustrate that after 1 week of having this thing I am beginning to doubt my sanity!
Chasing the heavies from a secret bunker in Scotland
EK01
Brimon,
Go to Map and scroll down to radar rings and click on that. You'll get what you need.
Cheers,
WAL 2T
It's worth checking out which upper airways are close to your location. There's an option to switch them on in aviation signs overlay but not sure how up to date they are.
Either way you can get the latest en-route charts from NATS (you want the North Sheet in ENR 6.3.0)
http://www.nats-uk.ead-it.com/public/index.php%3Foption=com_content&task=blogcategory&id=4&Itemid=11.html
Chris
Under the EGGP 27 Centreline & 15nm from EGCC
Brimon
Ian I have the radar rings up,but the sticky back plastic solution was purely for convienece & a rough guide as to where I should be looking.
Chris,I "cough cough aquired" a disc full of charts,Jepperson etc some time ago & have also used the nats site frequently.Thanks for the heads up.
WAL 2T
Good stuff there Brimon, didn't mean to teach grandma to suck eggs ;) Now i'd suggest painting the compass points on your patio but that probably wouldn't go down too well with your better half. A nice antique brass ships compass parhaps?
Chris
malc41
Sanity what is that. Oh reality the wife is home!!
15 Miles East of EGNJ
Brimon
#6
Quote from: WAL 2T on May 07, 2009, 02:52:29 PM
chris,Don't give me ideas! then again....I may surreptitiously order one of these sundial type patios & ensure that it is aligned north with flagstones for the other points.
Brimon<gets spade out,if not to lay patio to hit wife & bury her under it with her butt pointing north of course!
malc41
Would that not interfere with your line of sight?
Brimon
Quote from: malc41 on May 07, 2009, 03:32:21 PM
Malc, Damn never thought about that! Look on the bright side it would give me a good place to stick the antenna!
malc41
Brimon
malc41
Now that is some comedian!!!
