Lots of Mode S IDs with no data (question)
Started by perezoso, May 08, 2009, 03:08:46 AM
perezoso
Many, perhaps the majority of aircraft I receive in Bogotá transmit a Mode S ID for which there is zero information in the database.  No registration, no photos, nothing.  Most of these are Colombian IDs, along (so far) with a few more from the region (Venezuelan, Ecuadorean, Caribbean, etc.).
If I got motivated to do it, how would I start to link these Mode S transmissions up with actual aircraft information?
A related issue:  Lots of aircraft (maybe 15%) that I get are US-registered planes that have been sold (leased?) to Colombian airlines.  Well, at least they are still sending a US Mode S code.
Anyway, I get lots of Dash and similar aircraft that come back as being US Airways, Mesa Aviation, or some other US regional carrier.  Obviously those carriers don't fly small planes in Colombia and these aircraft are being operated by Colombian carriers.  When and how does this info get updated?
Thanks,,
Perezoso
Brian
#1
Have you looked up those Mode-S codes on these websites.  It might show newer information for those aircrafts.
http://www.airframes.org
http://www.gatwickaviationsociety.org.uk/modeslookup.asp
I also been trying to get the AirNav Database updated so other RadarBox users can also get the new updated data.  I been dealing with few aircrafts where AirNav Systems database is still showing old information for over 1 or 2 years.
What needs to be done.  Have a web interface where us RadarBox Users can Add/Change information.  If the web interface is done right.  It could have a 'Database Updates" page where it would show what has been updated.
like ("Changed" , "Admin Name" , "Date Changed")
It would also fix those blank(...) data the database sends out in the ICAO field.
I just wish it could be done.  but the past few months AirNav Systems doesn't want to help us RadarBox user with a way to get better data to us users. :(
-Brian
RadarBox User Forum
http://radarspotters.eu/forum/
#2
Its not a simple as its seems Brian.
This has been brought up before and westated we don't want to create an independant database like that as we feel regardless it will never be 100% correct and we will stick end up getting stick for it as customers will say it should be updated Proffesionally.
We are running off the GAS system and there system is based in a similar way. There are some issues in some of the links between GAS and us which we are looking into.
However at this time we do not feel we should take that route when GAS is already there. Creating a system as you mention would increase the cost for us and also go over ground that GAS has covered anyway.
malc41
15 Miles East of EGNJ
Brian
#4
What happens when GAS closes up shop one of these years.  Then we us users are left behind with a outdated database.  Till AirNav Systems tries to do something to fill in the gap.  Just need a backup plan before it happens.
-Brian
RadarBox User Forum
jgrloit
The other part of the question, which may be resolved in 2.10, is how go updates to existing entries get triggered, when for example operators change?
Or in US mode - the entire Airframe for a specific Mode-S gets changed?
Based in Hexham - Tyne Valley
kdt1
#6
2.10 fingers crossed,legs crossed, eyes crossed
Firstly the data is GAS is passed to across to our main server (or should be though the link has a few issues in some areas). So if they dissapear we will at least have the data.
As mentioned in a earlier post which had similar posts as above the changes required need a rethink of the whole database system and server link. Sorry but these changes will not be in 2.10.
kdt1
So It is what it is and there is no foreseen fix on the horizon as of yet.
Could you have RB just populate the pictures from airliner and have GAS fill in the correct operator or owner along with the aircraft info?
What we have now is just not working for South, Central and North America.
I am sure GAS could make a populate utility to help with this.
I just don't see Airnavs RB business growing in the US with out some sort of fix here.
ACW367
perezoso
I also suggest that you join the mode S yahoo group.
http://groups.yahoo.com/group/Mode_S/
They have members in Brazil, Mexico etc that may be able to help with the airliners.
Unfortunately as you are probably the first one in your part of the world to decode the aircraft.  Your best bet will be to take your Radarbox with a laptop to the airport and tie up aircraft in myflights visually with aircraft arriving.
kdt1
ACW367 that's a good idea, Perezoso it looks like a few RB logs have been generated from the Brazil area
perezoso
#11
I'd probably get arrested if I took the RB to the airport.  But even if I did, I typically have 5-6, sometimes 8-10 unidenified Mode S signals at a time. I don't know how I could accurately tie them up because I don't know how I'd know which was which.
Ran the box for a couple hours today, still with a temporary antenna hookup, here are all the unidentifieds I got:
   Mode S  Flight   Route           Regist  Airc  Airline              Date and Time
   0AC06C                                                              2009/05/08 17:54:19
   0AC09D                                                              2009/05/08 18:32:54
   0AC0CA                                                              2009/05/08 18:24:03
   0AC096                                                              2009/05/08 22:50:38
   0AC072                                                              2009/05/08 17:14:58
   0AC097                                                              2009/05/08 22:50:38
   0AC0C3                                                              2009/05/08 22:50:38
   0AC05F                                                              2009/05/08 17:55:30
   0AC06D                                                              2009/05/08 18:32:45
   0AC06A                                                              2009/05/08 18:03:30
   0AC027                                                              2009/05/08 16:43:42
   0AC0C2                                                              2009/05/08 16:37:21
   0AC054                                                              2009/05/08 17:29:18
   0AC06B                                                              2009/05/08 17:37:08
   000001                                                              2009/05/08 17:10:16
   0AC0D4                                                              2009/05/08 17:17:12
   0AC0A6                                                              2009/05/08 17:13:37
   0AC099                                                              2009/05/08 17:35:13
   0AC0D2                                                              2009/05/08 18:33:15
   0AC0C1                                                              2009/05/08 16:27:19
   0AC066                                                              2009/05/08 18:03:46
   0AC094                                                              2009/05/08 17:17:12
   0AC052                                                              2009/05/08 22:50:38
   ADFD7A                                                              2009/05/08 15:56:09
   0AC0B1                                                              2009/05/08 17:29:28
   0AC069                                                              2009/05/08 17:46:39
   0C6009                                                              2009/05/08 22:50:38
   0AC08C                                                              2009/05/08 18:03:34
   0AC063                                                              2009/05/08 18:33:15
   0AC0C9                                                              2009/05/08 18:22:35
   0AC098                                                              2009/05/08 18:03:43
   0AC00D                                                              2009/05/08 18:33:48
   0AC09A                                                              2009/05/08 17:01:57
   0AC0A1                                                              2009/05/08 17:08:50
   0AC0D1                                                              2009/05/08 17:33:59
   0AC02C                                                              2009/05/08 17:55:43
   0AC06F                                                              2009/05/08 18:18:42
   0AC04A                                                              2009/05/08 17:52:39
   0AC042                                                              2009/05/08 16:38:35
   0AC08D                                                              2009/05/08 22:50:38
   0AC071                                                              2009/05/08 17:31:58
   0AC0CD                                                              2009/05/08 16:14:45
   0AC0AC                                                              2009/05/08 16:50:10
   C80000                                                              2009/05/08 18:31:33
* 0AC058                                                              2009/05/08 17:42:19
* 0AC039                                                              2009/05/08 18:20:26
ACW367
Perezoso
That is a dilemma, I guess you can't use airband to even attempt to identify callsigns against height in an airport arrival stream.
Hi Perezoso
When version 2.1 of Radarbox software is released, you might well find that many of these unidentified aircraft will show flight ID's, and that will help in pinning down the aircraft.
ACW367
Perezoso
Although not giving tie-ups this website may help.
http://www.cgna.gov.br/CARSAMMA/siteUSA/areaofatuation.htm#
It is the ICAO RVSM agency for you region.  On the websites of some regions they give Mode-S tie ups.  However for the South America they only give registration.  Look on the monitoring tab and go to approved aircraft.
Here is the middle east version which has tie-ups
http://www.midrma.com/rvsm_approval.php
