My Flights List......future request
Started by b744, October 07, 2007, 06:03:56 AM
b744
When I loose a signal,if only for a moment, the altitude blanks on the My Flight list. Can you adjust this so the last known alt remains until the aircraft times out.
This would help very much if sorting by alt. and gives you more idea as to where aircraft are/were.
#1
A bit of catch 21 situation here. In the past we have had what you mention regarding last altitude but in some cases in poor reception areas where the aircraft jumps in out of your reception you can end up with spurious altitudes being shown (due to Mode-S and ADS-B alts received).
Anyhow will pass this on and see whether it can be done without bringing back the issue above.
b744
#2
would it be possible to have the option to save in a "my log" type listing, the network flights over a set period. To be able to look at this data in your own time could well lead to a number of aircraft being tied to hex codes.
rgds
any thoughts on this one ?? Does silence mean not a do-able request ??
