Has anyone put supplied aerial in loft? results?
Started by atcukmatty, June 06, 2009, 07:30:30 PM
atcukmatty
Hi, was wondering if anyone had put the antenna that is supplied with radarbox in the loft.... if so did it make much difference?
i am on the 2nd floor of my house and wondering if i raised the antenna another 20 foot higher to loft would it make much difference?
thanks
daveg4otu
Can't answer your question because until now mine has been outside - but - if and when I  get it repaired (just died again) I am now considering the the idea  of using the loft as a possibility .
The main question I would  want the answer to , which is equally relevant in your case is ...what level  of signal attenuation is likely through roof tiles?
Obviously - the higher the better - I've found even a couple of feet can make a difference in some cases - but  the  extra height may possibly be cancelled out by  the attenuation....
So - hopefully someone here may be able to offer advice from their own experience.
atcukmatty
well thinking about it i would say there would be more attenuation in the double layer of bricks than roof tiles?
daveg4otu
I think that obviously  that is going to be an improvement if you  presently have the antenna indoors somewhere- but   I  would  be interested in the attenuation as compared with  an antenna that is in the clear.
atcukmatty
so you had the supplied desktop antenna outside? what is the difference in signal from inside to outside?
#5
I've always had my antenna mounted in the loft with good results.  See previous discussion at http://www.airnavsystems.com/forum/index.php?topic=2528.msg21836#msg21836
My roof construction is concrete tiles over sarking and breeze-block gable ends.  The tiles cause little problem, but the gable end walls limit reception in those directions.
atcukmatty
thanks for reply tarbat. when you say 'antenna kit' are you talking about the one supplied with the radarbox.
i see your polar diagram but whats the comparison like when its not in the loft?
#7
The "antenna kit" is the external antenna and pre-amp and cable kit available from Airnav.   For a comparison of standard antenna vs. the antenna kit in the loft, see http://www.airnavsystems.com/forum/index.php?topic=1650.msg12949#msg12949
http://www.airnavsystems.com/forum/index.php?topic=1302.msg10765#msg10765
Sorry, I've never run with an external antenna, it's always been in the loft.
EMA
I use a loft mounted whip, from my location Derby/Notts my polar diagram goes as far north as Glasgow and as far south as the French coast. East/West is more limited due to high trees, I did have an external antenna but found little difference so had it removed after a local ligthning strike
EGNXR
Quote from: atcukmatty on June 06, 2009, 07:30:30 PM
thanks
1st image is standard aerial outside at gutter hieght.
2nd image is standard aerial in loft.
3rd image is an 1105c at chimney height this is about the same as the standard aerial at full stretch of the supplied cable its just mounted a little less precariously due to to the longer run of cable supplied.
hope this gives you a reasonable comparison
Cheers John
Based in Derby 5Nm NW of EGNX
atcukmatty
thanks EGNXR, interesting results there.
In the second image (loft) is that the tiles which are making attenuation north and south. east and west seem to have a fairly good range
EGNXR
Hi atcukmatty,
North south is the end brick walls- east west is through the tiles
The house runs 330-150 deg along its length if that makes sense in the polar diagrams tiled roof faces 60-240deg
HTH Cheers John
bearcat
Below is a screnshot with my supplied antenna in the loft connected by 20mtr of W103 with no pre-amps. I just tried different positions to get the best results. My range to the north west is limited a bit due to the chimmney breast.
Stewart
I tried it with the supplied aerial but the results were poor with a considerable loss of flights due to both length of aerial cable and roof tiles.
The majority of my traffic is south, so I am satisfied to concentrate on that direction and resist the temptation to sacrifice some of that traffic for odds and ends from elsewhere.
Essentially I've got 180 degrees and that's fine.
imropes
Made a massive difference to me. Icould not get the aeriel to a window (comp cant be moved) I put it originaly on top of door pick up was poor (old building solid walls) I put rb in small wire basket at top of door which gave me a bit more coax to play with.Its half way up to roof apex and its fantastic. Max range to the east. Give it a go.
