Driver for Vista?
Started by ChainHome, June 09, 2009, 01:14:45 PM
ChainHome
I have just received my RadarBox 2009 and am having difficulty connecting to my Windows Vista Home Premium machine. The hardware light shows yellow and states: "Hardware: Checking". I have removed the driver and re-installed (Version 2.2.4.0 dated 27/06/2007) with no better result. The system installs perfectly on a laptop running Windows XP.
Anyone got any (helpful) suggestions?
Geoff
malc41
Have you checked in the FAQ's the post reference install in vista?
15 Miles East of EGNJ
ChainHome
Yes. That just seems to clear up the compatibility files problem (i.e. finding the files that used to be filed along with the Program Files under XP).
This seems to be a driver problem since the program will not recognise the hardware while the Control Panel/System says that everything is fine!
At least I can watch live traffic via the laptop (but that isn't connected to the internet).
Geoff
colinhall
I have got Vista on my laptop and I had no problem putting it all on there providing you switch the "user accounts" to off then it might allow the hardware to be down loaded, hope it works for you. Colin.ps dont forget to turn the user accounts back on afterwards.
If it helps, the driver in Vista should look like this
malc41
Tarbat what wuld we do without you!
ChainHome
Yes that's the way it looked but it was Colin that hit the nail on the head! Sometimes Vista can be a real pain!
Apparently, if you install the driver with the User Accounts feature turned on, the driver is loaded where Vista can recognise it (but perhaps the program can't access it). I suppose that the way to get around all this is to install somewhere other than in Program Files (which is what the FAQ really suggested).
Anyway, thanks to some splendid help, I am now able to connect on both machines. Thanks again, fellows.
Geoff
malc41
#7
Geoff
Yeah, found that myself with Vista, good old Microsoft trying to run our lives again! or should that be ruin?
freqhopping
#8
I just got a new laptop and of course it has Vista, no luck getting XP to install on it either.
My RB won't work.  I don't even get network traffic and it says it's connected.  UAC is turned off. This is what I see for the driver.  What folder does the driver need to be saved in anyways?
puddy
#9
I am a new user and using vista ultimate edition using uac switched on and have had no problems!
could your anti-virus program be blocking airnav dont forget Vista anti-virus and windows firewall?
Try below to install airnav drivers in vista
Please note all this will be done within device manager!!!
for RB driver go my computer> system Properties>device manager>delete airnav driver if loaded found in USB right mouse click and choose uninstall driver place a tick in delete driver software for this device>ok
unplug the radar box and plug back in a box will pop up found new hardware click canel button.
You will now find AirNav RadarBox will be listed in other devices>right mouse click once on the  airnavRadarbox>click update driver software>click browse my computer for driver software> (Tick Include subfolders) then click the browse .
You will find the airnav folder in program files >airnav RadarBox 2009 > drivers> click driver folder once> click OK>click next
2 popup boxs come up the one we need will come up " windows cant verify the publisher of the driver software" click install this driver software anyway.
A box will come up windows has successfully updated your driver software click close
Puddy
freqhopping
I've done all that and the final result is what is displayed in my attached images.  Until I have a working driver nothing else matters.
solarix
You might have 64 bit edition. I have to press F8 (before Windows boots) and disable driver signature enforcement during boot. It's a pain but only way to work until they new driver can be released.
puddy
Quote from: freqhopping on June 16, 2009, 01:37:32 AM
if you followed my instuctions the images you listed do not come up at all.  give it a try again
puddy
freqhopping
Quote from: puddy on June 16, 2009, 09:47:03 PM
puddy
What I posted is a result of doing just that.  However, after disabling driver signature enforcement before booting it started working as soon as I plugged it in.
