Info for future ITALY user
Started by LELE AIR, June 11, 2009, 04:35:36 PM
LELE AIR
Hi to all, i'm approaching buy RB in nex weeks, but i've some question about it
1-are aircraft pictures and flights routes (EGLL-LIMC for ex.) already incl. In sw, or are available only if my PC/Laptop is online with internet connection (so air nav link to A.net for downloading photos?)
I'm not able to connect to internet so for me air nav sw is basically important.
Is possible to download my picture collection in RB sw? for using?
2-I live in Italy MXP-LIN, can i see/recognise airport, apt code,VOR also on the map, or (like others) is available only for UK,EIRE?
3-is there some anti-static filter or something else for reducing static danger! buying directly for W&S?
i'm very kindly of your reponse, pls use  simple Eng llanguage..sorry!
Thank you from now
LELE
Our support will address your questions.
In the meanwhile have a look at some great screen shots created by another Milan based user:
http://www.airnavsystems.com/forum/index.php?topic=2790.0
sterigia
you should see linate in attached file like i do
frank, sardinia
ps mi pare sia vietato usare il radarbox in italia, informati meglio
ciao
ciao.
frank
Starting to answer your questions:
1- All pictures are available online and will be downloaded when needed. They are after that saved on your computer. If they are needed again then they will be retrieved from your computer (no need to download again). Same for flight information.
2- RadarBox comes with an updated worldwide airport, runway, VOR, NDB, etc database. V2.10 to be released in a few days contains the last AIRAC cycle for all the world (more than 200 thousand data). This data was imported from official aviation sources.
3- No need to concern about this as only a few users in thousands have experienced this problem. Anyway our support will send you details on that.
sterigia
or this one shot now with less magnification
frank
ciao.
frank
Jordan
Was wondering about the Antenna kit, is it the one that costs around 30 Pounds?
and it includes an AMP?
LELE AIR
x sterigia: NON esiste nessuna legislazione in merito, meno ancora che per gli SCANNER radio, conosco diverse persone che lo usano senza problemi...dovrei NOn comprarlo?scusa ma tu non lo usi!
Thank you to ANDev. and Suport and to all for all precious info
So
It's impossible to download my picture collection in RB sw? for using?
and have all photos or flight info without internet connection.
Thank you again
LELE
Lele  - Mi pare che Internet Connection broadband e indispensabile per Radarbox.
LELE AIR
NO absolutely it isn't indispensable for RB, you can track flight without internet connection...i've try it
Or so around apta ..how do you do??internet keys...ahhha no no
sterigia
certo che lo uso, è come gli scanner che uso dagli anni 80, puoi comprarli ma non puoi ascoltare nulla al di fuori delle trasmissioni commerciali, almeno così mi pare.
compralo è meglio dell sbs 1 ma l'antenna deve essere fuori, a cielo aperto, altrimenti senti solo traffico locale.
io uso l'ant del sbs1 che ho su un palo sopra l'antenna televisivia ma sono coperto da montagne quindi al massimo arrivo a palermo da casa mia. se non hai internet vedi solo quello che avviene attorno a te. se vuoi vedere il feed dagli altri devi avere l'adsl per forza
ciao
frank
ciao.
frank
quote author=LELE AIR link=topic=2835.msg25117#msg25117 date=1244796516]
[/quote]
Yes - but you can get no photos, no updates of information and no network service.
LELE AIR
Ciao Sterigia, finalmente qulcuno che parla italiano qui...si si confermo tutto  io l'ho provato un mio amico da casa sua è venuto da me è prende con antennina sul balcone appoggiata..voglio chiederti alcune cose, quindi nel momento in cui lo compri lui nel sw ti da: n.volo, logo e altri dati, foto e rotte invece no, le scarica da web,giusto?, quindi in teoria basterebbe collegarlo ogni tanto.
NO ti spiego io nn ho adsl...non ho niente e unica ciosa che potrei fare è acquistare la chiavetta internet key (che nn so che velocità possa avere!!!).
Sul fatto che sia meglio del SBS cosa mi dici. solo x il sw o anche per altro. Credo cmq che prendano uguale a livello di campo.come mai uso antenna sbs.
grazie di tutto quello che mi dirai..
lele
Sorry but one of the rules is to keep the posts in english. Otherwise we have no idea whats being said :)
